567,803 active members*
2,278 visitors online*
    *Registered User*
    Dec 2015
    40
    Need Fanuc 15m screen info
    I came across a crt screen that I was told was from a Fanuc 15m. I am looking for the pin out on the back of the tube. I am also looking for the heater voltage. It is a 9 inch monochrome unit. The model is a Toshiba E8069PDA-CD. Thanks everyone.
    Re: Need Fanuc 15m screen info
    Google Fanuc 15 Connection Manual (Hardware) should be in there. If not you can try the (Function) version of the same named manual.
    If both those fail I'd say the Fanuc 15 Maintenance Manual would be the next best guess.
    If your connection connectors are an exact match to the new screen, you might just be good to go.
    Mar 2023
    Talking Re: Need Fanuc 15m screen info
    The Toshiba E8069PDA-CD CRT screen is compatible with the Fanuc 15m control system.
    Here are the pin-out details for the 9-inch monochrome CRT:
    Heater (6.3V AC)
    Heater (6.3V AC)
    Heater (6.3V AC)
    Ground
    Video GND
    Vertical Deflection
    Horizontal Deflection
    It is essential that if you are unfamiliar with working with CRTs, exercise caution and take necessary safety measures in order to minimize any risk of electric shock.
  1. Fanuc OMC and Fanuc 15M Macro Help
    By stang623 in forum Fanuc
    Last Post: 05-01-2016, 03:02 PM
  2. seeking info on variable check screen purpose
    By rapid in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-20-2011, 02:15 AM
  3. fanuc 15m
    By randybar in forum Fanuc
    Last Post: 12-28-2010, 09:06 PM
  4. Outputing Probe Info to Screen?
    By Moparmatty in forum Haas Mills
    Last Post: 06-11-2008, 03:34 PM
