547,600 active members*
2,602 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > Need help buying plasma torch for AvidCNC table
    Oct 2016
    Hi There!
    I have an Avid 5x10 dual Z-axis table (spindle and plasma).
    I've got the spindle setup working and am currently building a vacuum table for routing. It won't be long and I will start in on the plasma portion of it.
    I purchased the plasma kit from Avid and incorrectly assumed it included the plasma torch (not the whole plasma cutter, but just the long cylindrical torch head - I think Hypertherm calls it a "machine torch").
    I have been planning on buying a PrimeWeld Cut60 plasma cutter and thought that the idea was to just connect the Hypertherm machine torch head to the Cut60 cutter.
    I've emailed Avid back and forth. I ask about the torch and customer support is trying to sell me the entire Hypertherm plasma cutter (obviously, either I or they are misunderstanding).
    The PrimeWeld Cut 60 includes a Euro Central Connection for the torch. What reasonably priced torch could I buy that would work with the Avid plasma torch mount and kit?
    I found this on eBay. Is this an option? Is there something better?
    https://www.ebay.com/itm/22377957314...MAAOSwqQpd6c~l
    Thanks!
    Jan 2016
    64
    Re: Need help buying plasma torch for AvidCNC table
    Why get a Hypertherm generator and a different torch? No reason to mix and match. Just get the Hypertherm setup. That is what I did and it works great.
    Sent from my iPhone using Tapatalk Pro
  1. Old Plasma and Torch table needs new controller
    By dwooder in forum General CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 07-21-2015, 03:26 AM
  2. Maybe buying a plasma table
    By Ismaster in forum General CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 06-17-2014, 08:52 PM
  3. Plasma table and torch warranties...
    By Sykosys in forum General CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 05-06-2013, 06:51 PM
  4. opinions on Dyna Torch Plasma table
    By Matt T in forum DynaTorch
    Last Post: 12-11-2006, 06:35 PM
  5. Buying cnc plasma table
    By xavier2nd in forum General Waterjet
    Last Post: 07-18-2006, 07:29 PM
