504,500 active members
3,533 visitors online
IndustryArena Forum > OpenSource CNC Design Center > Arduino > Need Help... CNC 3018 Stopped, GrblController connected but cannot move X, Y, Z
    Jul 2019
    Question Need Help... CNC 3018 Stopped, GrblController connected but cannot move X, Y, Z
    The CNC was executing a project and noticed it drilled deeper than I expected, and it moved as it should be given by the commands. Then the spindle and the stepper motors stopped just before I clicked on Abort on the GrblController application.
    I closed the GrblController and reopened it, then the whole CNC does not execute any commands (moving X, Y, and Z, and turning the spindle on and off.
    Any idea why this happened? I tried googling around for the same issues as mine, I haven't had any luck yet. I have also tried to pull the plug on the CNC and restarted my PC, but it doesn't help.
    Jul 2019
    Re: Need Help... CNC 3018 Stopped, GrblController connected but cannot move X, Y, Z
    I was able to get it working. I just turned it off for an hour or two.
    Mar 2015
    241
    Maybe something was getting hot or a Windows update (background) spoiled the fun.
    Powering everything completely of and then starting again is probably one of the most successful problem solving solution in our computer world.
  1. 3018 CNC
    By joemanbel in forum Chinese Machines
    Last Post: 05-18-2019, 11:32 AM
  2. Woodpecker 3018 cnc with a euro plugin
    By 1stcontact590 in forum General Off Topic Discussions
    Last Post: 05-09-2018, 05:23 AM
  3. A couple of questions about a 3018.
    By cncbeard in forum Chinese Machines
    Last Post: 04-25-2018, 04:09 PM
  4. Can I engrave glass with a 3018.
    Last Post: 01-21-2018, 06:38 PM
  5. CNC router suddenly stopped reacting to move commands
    By Venretus in forum Commercial CNC Wood Routers
    Last Post: 07-08-2017, 02:51 PM
