567,775 active members*
1,690 visitors online*
IndustryArena Forum > CAM Software > CamWorks > Need Help! Depth Per pass problem from Fusion360 to Candle
    Hello:
    I'm very new in CNC and don't know if this will be a bit out of topic here, I really apologize if that's the case.
    I'm trying to make some pieces from Aluminium and the pockets comes out well but, when I try to make a 2D contour to separate it from the plate it always goes to 3mm depth instead the 1.5mm I have specified.
    Maybe I'm trying to put the depths with the wrong "tool", I'm using "Multiple depths".
    In the simulation appears correct, can be it a problem with the post processor? (I use GRBL) May it be a problem between Fusion and Candle?
    Nov 2013
    2590
    Re: Need Help! Depth Per pass problem from Fusion360 to Candle
    I use Fusion and you are correct to use 'Multiple Depths', but are you setting the required depth passes?
    Craig
    Attached Thumbnails Attached Thumbnails FusionMultipleDepths.jpg   FusionMultipleDepthsToolpath.jpg
  1. Y axis offsetting itself at each depth pass ?
    By karnalta in forum LinuxCNC (formerly EMC2)
    Last Post: 12-31-2022, 02:27 AM
  2. pass depth and feed speed for a profile cut
    By Alexone in forum Milling
    Last Post: 04-05-2019, 05:55 PM
  3. cut depth per pass
    By christ371 in forum Dolphin CAD/CAM
    Last Post: 07-20-2008, 03:14 AM
  4. Replies: 13
    Last Post: 01-10-2006, 03:22 PM
