591,381 active members*
7,367 visitors online*
    Sep 2019
    17
    NEED HELP FANUC DRILLMATE c model 10!
    Hello everyone,
    I have a 1992 fanuc drillmate c model 10 with an O-M controller. Operator recently ran drill thru a metal paint scraper and it bounced around trapped between the part on the fixture and the drill. The machine was emergency stopped and reset. Immediately the tool carousel started making a loud noise when it changed tools. 1 day later the tools started dropping out of the head. This machine has no air or hydrolic to change tools it works mechanically. I have no errors or alarms the tools just fall out when the head comes down to grab it then i get a 1006 tool alarm because there is no tool in the spindle. I used m19 to orient the spindle and that is definitely lined up with the y axis. So I am trying to take apart the head but I can't figure out how to get it apart. Fanuc said the machine is too old and they don't have files for how it's put together. Also called methods and they can't help either. If anyone has any drawings of this machine spindle assemble I would be very grateful. Or ideas how to take it apart . Thank you in advance if anybody has any suggestions.
    Sep 2019
    17
    Re: Need help fanuc robodrill c model 10!
    Sorry I don't know how to edit my first thread. The machine is a 1992 fanuc DRILLMATE C MODEL 10
  1. Proper setup forFANUC ROBODRILL D14siA Control 3Ii-Model B
    By ADMAN in forum Uncategorised MetalWorking Machines
    Last Post: 07-19-2019, 08:31 AM
  2. New Fanuc Robodrill or 7000 hour robodrill with all the bells and 4th axis?
    By The_R1_Kid in forum Uncategorised MetalWorking Machines
    Last Post: 09-20-2018, 01:26 PM
  3. Fanuc Robodrill Alpha 31i A5 model
    By Amboy in forum Fanuc
    Last Post: 02-21-2016, 10:47 PM
  4. Replies: 1
    Last Post: 04-14-2014, 07:41 PM
