525,612 active members*
2,428 visitors online*
IndustryArena Forum > GENERAL MANUFACTURING PROCESSES > MILLING > need help for two sided milling
    Post need help for two sided milling
    Dear All need help for two sided milling operation like how to do it . i will be thankful for answers i want to create mould for phone case as per attachment on my arduino 3 axis CNC machine PFA.
    want to design in solidworks and autodesk hsmworks for toolpath generation or any other easy eay please help.
Name:	WhatsApp Image 2020-07-17 at 2.07.35 PM.jpg
ID:	446759Click image for larger version.
Name:	WhatsApp Image 2020-07-21 at 1.04.38 PM.jpg
ID:	446761Click image for larger version.
Name:	WhatsApp Image 2020-07-21 at 1.05.46 PM.jpg
ID:	446763Click image for larger version.
Name:	WhatsApp Image 2020-07-21 at 7.32.39 PM.jpg
    Jul 2020
    Re: need help for two sided milling
    What are you asking? How to do the other side?
    Gold Member
    Apr 2004
    5052
    I'd suggest using the 2-side milling wizard in DeskProto, which makes it easy for you. But failing that, you can make a fixture with pins coming up that slide through holes in the workpiece. Set it up so that the Y zero is in the center of your part, then create a new part for the other side that is rotated 180 degrees around Y., and generate toolpaths for that side. After doing the first side, flip it over, slide it down on the pins, which should be at the Y=0 point on either side of your part (out of harm's way). Clamp it down and run the second set of toolpaths.
    Andrew Werby
    Website
