515,369 active members
8,462 visitors online
IndustryArena Forum > CNC Electronics > Spindles / VFD > Need Help!- Huanyang VFD + Usb 4 Axis Mach3 100 Khz Usb
Results 1 to 4 of 4
    Oct 2019
    3
    I have this controller Usb 4 Axis Mach3 100 Khz Usb, and Huanyang VFD, I tried everything, but it didn't start some help ?
    Attached Thumbnails Attached Thumbnails s-l1600.jpg   IMG_20200215_073320.jpg   IMG_20200215_073343.jpg
    Jan 2005
    10788
    Re: Need Help!- Huanyang VFD + Usb 4 Axis Mach3 100 Khz Usb
    Quote Originally Posted by taths View Post
    Do you have a wiring diagram you can post of the Breakout Board, it does not appear to have a Relay or PWM 0-10v analog output
    Mactec54
    Oct 2019
    3
    Thanks for the answer, photo with connectors,sorry for my english, i use translation.
    Jan 2005
    10788
    Check that the ACM and DCM are the same if not they can not be connected / wired like that ACM is Analog Common DCM is DC Common
    FWD and output 2 I don't think will work for your VFD Drive, what does output 2 do, if this has voltage then it will not work it would have to turn a Relay On / Off to be used if it has a voltage FWD and DCM is just a switch with no voltage to make the VFD Drive turn On / Off
    Mactec54
  1. Replies: 30
    Last Post: 06-17-2019, 04:02 PM
  2. Huanyang VFD 2.2kw to mach3
    By AllanUrup in forum General Off Topic Discussions
    Last Post: 03-27-2017, 11:52 PM
  3. Need Help with 5 Axis Bob / Mach3 / Huanyang Spindle Setup
    By sbloom67 in forum DIY CNC Router Table Machines
    Last Post: 03-27-2017, 03:22 AM
  4. huanyang vfd and mach3
    By Elektryk in forum Phase Converters
    Last Post: 07-29-2013, 05:14 AM
  5. Huanyang 2.2kw VFD PWM Mach3
    By Kkatkhuda in forum Phase Converters
    Last Post: 11-14-2012, 02:31 PM
