587,006 active members*
2,795 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Need help identifying this 4th lube line on my Haas DM-1
    May 2013
    170
    I'm in the process of purging my lube lines to unclog the lines.
    On my manifold inside the cabinet I have (4) Lines
    One is the X-Axis
    One is the Y
    One is the Z
    But I'm not sure what this extra line is ( the one with the yellow arrow )
    I'm guessing the spindle? ( but isn't that being lubed from the oil tank at the bottom of the cabinet? )
    Thanks,
    Kent
    Attachment 504588
    May 2013
    170
    Re: Need help identifying this 4th lube line on my Haas DM-1
    Just a quick update.....
    I followed the line and it goes to the side tool carousel gear
  1. VMC 4020 way lube line
    By yeepman2 in forum Fadal
    Last Post: 04-11-2013, 05:10 PM
  2. HAAS Lube
    By dayton murdock in forum Haas Mills
    Last Post: 03-10-2011, 02:56 PM
  3. Haas lube pressure?
    By UBRacing in forum Haas Mills
    Last Post: 10-28-2010, 02:04 AM
  4. Lube line help
    By advt001 in forum Fadal
    Last Post: 06-27-2009, 01:24 AM
  5. Broken lube line - how to make new one?
    By SRT Mike in forum Uncategorised MetalWorking Machines
    Last Post: 07-21-2007, 05:56 PM
