528,200 active members*
2,352 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Need Help!- Milling a clock hand with Mastercam -- toolpath?
Results 1 to 5 of 5
    Aug 2010
    5
    Hello,
    I have created a dxf drawing as well as 3D model of a clock hand I would like to make from a piece of flat metal, which is already the correct thickness.
    I am new to mastercam and have been struggling for several days to get through splines, chaining, extruding etc try and get it to do what I want - to no avail.
    The only toolpath I managed to generate successfully was dynamic and it wants to remove heaps of stock and leave my hand as a boss on top of the stock block with everything around it removed.
    That would take hours of machining with my slow little Sherline machine.
    So I would like it to create a toolpath that will follow the outline of the clock hand drawing or model and repeat this operation until the correct depth / break through is reached.
    What toolpath type do I need to for this and how would I set that up?
    I will be using a 1/16" endmill and I have created that already.
    The hand design is such that a 1/16" will be able to cut all the curves so no issues there.
    Any help or advise, is greatly appreciated.
    Jul 2020
    9
    Re: Milling a clock hand with Mastercam -- toolpath?
    Just do a contour with depth of cuts set to the amount desired. If you want to send the file over, I will be glad to look at it.
    Gregwi@sfgsc.com
    Aug 2010
    5
    Hello,
    Thank you. I have emailed you the files. I have also attached the files here too.
    My attempts of creating a 2D countour path have all failed.
    In hand3, I tried to create a groove of the diameter of the endmill (1/16") but that also failed.
    Best regards
    Bernt
    Sep 2019
    4
    Re: Need Help!- Milling a clock hand with Mastercam -- toolpath?
    You can use 2D toolpath' 'Mastercam: Contour and Pocket.
    Or contact to me, help you: cammechco@gmail.com
    Mastercam Training
    Community Moderator cadcam's Avatar
    Apr 2003
    3543
    Did any one get you some sample paths for this? What version of Mastercam are you running?
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
  1. Mastercam Art Toolpath
    By platonas1 in forum Mastercam
    Last Post: 08-31-2016, 05:48 PM
  2. toolpath in mastercam x5
    By juniormachinist in forum Mastercam
    Last Post: 04-13-2011, 11:03 AM
  3. Export toolpath to mastercam
    By rdpdo in forum ArtCam Pro
    Last Post: 05-22-2010, 08:14 PM
