600,787 active members*
4,558 visitors online*
Results 1 to 6 of 6
    Jan 2007
    91
    NEED HELP - MULTICAM 5000 SERIES
    HI
    I am facing a issue with my machine, the machine shows error as " low air pressure" but when inspected the air flow is accurate and continuous, when i contacted multicam technician he said this might be due to blockage in solenoid valve causing some sensor inactive, he also adviced me to find good hydraulic technician who can fix it of.
    can some one suggest good information abot this issue
    Jun 2010
    465
    Need Help-Multicam 5000 Series
    Question when are you getting the low pressure error, is the low pressure error happening when you request to machine to find home or during program run.
    Jan 2007
    91
    problem starts when i am finding home.
    Jun 2010
    465
    1st thing have you tried to bypass the regulator in the rear of the machine, plug your shop air directly into the machine and try to find home.
    If you still get the the low air pressure error, put your shop air back in the regulator assy and reduce the air pressure on the guage down to 85 psi and then lets check to see if the low pressure sensor is out of adjustment, the sensor on the 5000 is PN# 94-01325-00 on the attached pic.
    On the sensors end there is small hole that you can take a small flat head screwdriver, clockwise increases the adjustment pressure, counter clockwise decreases.
    You also will see on the end of the sensor a small led light, with the light on the air pressure is high enough to complete the circuit, if the light is off the low pressure air signal is tripped, try to adjust this sensor and see if the error goes away.
    Jan 2007
    91
    thanks
    i tried what you suggested by fine tuning the pressure switch , i got my machine working well as it was, thanks a lot....
    Apr 2025
    Re: NEED HELP - MULTICAM 5000 SERIES
    I am receiving alarm messages safety hold any help for this issue
    Thank you my router is multicam series 5000
  1. OSP 5000 Alarm 201
    By cncatj in forum Okuma
    Last Post: 09-24-2014, 11:20 PM
  2. Question about a MultiCam 3000 Series CNC Router
    By dennisbwest in forum Community Club House
    Last Post: 07-30-2013, 07:33 AM
  3. OKUMA OSP 5000
    By copper in forum Okuma
    Last Post: 07-26-2010, 05:03 PM
  4. Multicam 3000 Series and Weeke
    By gusb in forum Want To Buy...Need help!
    Last Post: 04-16-2009, 10:34 PM
  5. Benchman 5000
    By machbuilder in forum Benchtop Machines
    Last Post: 09-01-2006, 01:04 PM
