547,337 active members*
2,458 visitors online*
IndustryArena Forum > CAM Software > Alphacam > Need help om programming a keyhole
    Aug 2021
    We have Alphacam Essentials and I need to program a keyhole. The bit will plunge down then move 10mm sloping down 2.1 mm. Then continue moving another 10mm and return to the plunge site at that depth then retract. How do I draw it?
    Nov 2008
    524
    Re: Need help om programming a keyhole
    Search on keyhole in vcarve. Since the software can’t handle the Z slope I would manually change the g-code. Lower Z at top of the U shape.
    Test in air to make sure it works.
  1. Xilog 3 Parametric Programming Offline Programming
    By julioykaly in forum Commercial CNC Wood Routers
    Last Post: 04-27-2013, 09:22 PM
  2. instruction parameter programming / macro programming
    By kickinger in forum Mikron / Haas
    Last Post: 08-31-2011, 10:16 PM
  3. Keyhole cutting with mazatrol m32
    By Oskimach in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-12-2010, 03:50 PM
  4. Replies: 2
    Last Post: 10-30-2004, 11:15 AM
