567,778 active members*
2,604 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller & Computer Solutions > Need Help on OSAI controller Y axis servo error) EE0011
Results 1 to 4 of 4
    Oct 2013
    107
    Post Need Help on OSAI controller Y axis servo error) EE0011
    Hello, I have a Techno HDS CNC router with an OSAI controller. The machine's issue is that it consistently displays the error code (Y axis servo error) EE0011. The error occurs while the machine is running, idle, or moving the gantry.
    I frequently try to restart the system, look for any weak connection in the cables on the y axis of both drives, unhook the cables, blow the connectors using compressed air, and then re-plug. but the error still occurs.
    The x-axis motor vibrates or generates noise while at idle, which is the second problem. The noise is not overly loud, but it is audible.
    Please provide us some advice on what else we should check on the system to diagnose the issue.
    Thank You
    Neuer Benutzer
    Jan 2013
    425
    Quote Originally Posted by M.Abid View Post
    Thank You
    Could easily be the axis motor, have it checked out.
    In my experience with osai, could be mechanical, belts, cables, drive or motor. Does your axis have a linear scale? It may be dirty causing oscillation and noise.
    Oct 2013
    107
    Re: Need Help on OSAI controller Y axis servo error) EE0011
    Quote Originally Posted by servtech View Post
    hi Pal
    the servo motors fixed with a gear reducer. The error comes on even at idle on the y axis motor.
    the sound / noise comes from x axis servo motor the vibration also touch to feel while the x axis at idle.
    Mar 2023
    Swap x-axis and y x-axis wires retrace
  1. Replies: 0
    Last Post: 01-18-2023, 12:57 PM
  2. Techno HDS CNC ( Y axis servo error) EE0011
    By M.Abid in forum Techno CNC
    Last Post: 01-07-2023, 12:15 PM
  3. OSAI Controller Producing HD021 Error
    By heftcabinets in forum SERVICE FOR CNC-MACHINES
    Last Post: 12-07-2022, 12:55 PM
  4. Error 414 Z axis error detect- servo alarm
    By andywids in forum Fanuc
    Last Post: 07-09-2009, 04:33 PM
