504,444 active members
5,015 visitors online
Results 1 to 10 of 10
    need help with set up
    I have just received a chinese 3040 cnc router and have set mach3 up to the manufacturers specs. The dro's move but not the steppers dont, I have power to the steppers (they are locked at power on) e-stop will operate on mach3 screen and reset ok,
    I have voltage at the parrallel port only 3 volts at pins 3,5 & 7 change from
    0-3v on operating of xyz axis and pins 2,4 & 6 stay at 3v and 4 volts on pins
    10, 11, 12, 13 & 15, the rest are all 0 volts and stay that.
    My set up is
    x step pi 2 dir pin 3 step low ac ticked step port 1 dir port 1
    y 4 5 same 1 1
    z 6 7 same 1 1
    all help would be appreciated
    john
    Gold Member
    Jan 2010
    2141
    Some controller boards have a difficult time with 3-volt parallel port signals.
    It may be necessary for you to consider installing a parallel port board in your computer that puts out 5 volts to the output pins.
    Is the controller that came with your router one of the TB6560-based boards? If you have access to an oscilloscope, you might want to probe the output of the optoisolator chips on that board to see whether or not your signals are getting through. There are some schematics of a typical TB6560 board in the following thread that may be helpful in your probing:
    http://www.cnczone.com/forums/genera...y_chinese.html
    if it needed 5v but only got 3v would the motors still move
    Gold Member
    Jan 2010
    2141
    It may not work on 3 volts - if the input signal voltage (on the step and direction and enable input pins) is not sufficient, it may not be able to trigger the driver to move the motor.
    May 2011
    It could be you lucky day.
    Here are the drivers for the 3040
    https://www.filesanywhere.com/fs/v.a...8d5f6372b3a2ab
    rob
    good luck
    May 2011
    John i just checked the voltage on mine its a 4 axis 3040H807050C
    there just under 5
    thanx guys
    I will try the drivers tonight
    john
    May 2011
    PS: The drivers are chinese.
    just keep clicking the left button.
    rob
    May 2011
    13
    Chinese 3040 cnc EMC2 setup
    Hello all,
    I too bought a chinese 3040 cnc this month, i spent a lot of time trying to figure out how to get it working, cause the documentation is hardly readable and parts of it is written in chinese. I finally got mine working and bellow are the setting i used for EMC2.
    Using the stepconf
    Units: Millimeter
    Driver type: other
    Step time: 5000
    Step space : 5000
    Direction hold :2000
    Direction setup : 2000
    First parport Base Add: 0x378
    Base period Maximum Jitter: 35000
    Parallel port setup
    Pin1 - Spindle PWM, Pin2 - Not used, Pin3 - Not used, Pin4 - Ystep (inverted), pin5 - Ydirection, Pin6 - Zstep (inverted), Pin7 - Zdirection (inverted), Pin8 - Not used, Pin9 - Not used, Pin10 - Estop in, Pin11 - Not used, Pin12 - Not used, Pin13 - Not used, Pin 14 - Spindle CW, Pin15 - Not used, Pin16 - Xstep (inverted), Pin17 - xdirection.
    X-AXIS CONFIG:
    Motor steps per revolution: 200
    Driver microstepping: 8
    Pulley teeth ratio: 1:1
    Leadscrew pitch : 4.0
    Maximum velocity 25 mm/s
    Maximum acceleration: 30 mm/s/s
    Table travel : -3.0 to 290.0
    Y-Axis config:
    Leadscrew pitch : 5.0
    Table travel: -3.0 to 390.0
    Z-Axis config:
    Leadscrew pitch : 2.5
    Maximum velocity: 15 mm/s
    Table travel : -10.0 to 35.0
    Spindle configuration:
    PWM Rate: 100.0Hz
    Speed1: 100.0 PWM1: 0.2
    Speed2: 800.0 PWM2: 0.8
    NOTE
    This setting is for my driver board, i think the 3040 comes with different driver boards, it may work in yours.
    I am still not very satisfied with the spindle settings, i feel am setting something wrong there. My spindle starts going off and on after working for close to 2hrs non stop. Am tempted to connect the spindle direct to main since its 240v 50hz. Right now its connected to the driver board control.
    I noticed that when i load a Gcode file the spindle immediately stops spining and the machine stops all movement in the X-axis. However i found a workaround by editing the Gcode file and erasing the directive M3 SXXXXXX (where xxxxx are numbers). This directive should turn the spindle on and set its speed but here it turns it off and disables the x axis.
    So far the machine works but am concerned about the spindle issue.
    Re: need help with set up
    I know this is an ancient thread, but for anyone looking for a solution to the X-axis problem (as I just was): change pin 14 from Spindle CW to not used. When set to Spindle CW, everything will work except the X-axis will not move when the spindle is on. Changing the pin to not used will allow it to work as expected.
