584,879 active members*
5,025 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Need help with angled pocket on BobCad
Page 1 of 2 12
Results 1 to 20 of 35
    Jul 2017
    16
    I have made a 3D model, but still cant get the neck pocket to cut smooth. Please help
    Apr 2009
    3376
    Re: Need help with angled pocket on BobCad
    a .dxf file,,such as you uploaded,is not a 3d model
    please include a .bbcd file or other such file that if a solid
    Jul 2017
    16
    It won't let me upload a BobCad file.
    Apr 2009
    3376
    Right click on your file and choose send to compressed folder...Now upload that file,,,it should be a .zip
    Jul 2017
    16
    Let's hope this works...
    Jun 2008
    1838
    Quote Originally Posted by SaintBlues View Post
    Try the attached file, may give you a bit of an idea on how to do the pocket
    Regards
    Rob
    Apr 2009
    3376
    Tryingle to figure out what is Angled in your pocket,,,as the Title says
    Jul 2017
    16
    The bottom of the pocket has a 3 degree angle. I need to mill this using a 3X mill. But every time I try it turns out rough.
    Jul 2016
    660
    Is this what you mean? The upper lines are smooth but the lower lines are angled, try to copy the upper lines then paste it on the lower portion to smooth it out.
    Jul 2016
    660
    I can make a custom CAM on this and post it here if you want I just need your bit size...(1/8-5/16) (3mm-6mm)
    Jul 2017
    16
    The bit is a 1/4 inch. I would like to know how it is done also.
    Dec 2011
    361
    Saint,
    The neck pocket, the bottom of the pocket has a slope of 3 Degrees if I am understanding correctly, is this correct? I will attach an example of this shape here shortly using the 3x pro toolpaths.
    Jul 2017
    16
    Yes, the bottom is sloped. The drawing has the slope in it. Will I be able to run the toolpath with a Baliegh WR-23 router?
    Dec 2011
    361
    Saint,
    I see no reason why not, the router itself can handle 3x motion. What toolpaths do you have available for V29? Do you have 3x pro toolpaths, or just standard?
    Jul 2016
    660
    Sorry I forgot, I need the exact length, width and height og the actual product you want to create, I just simply plot your DXF file on a 3D environment without the exact measurements
    Dec 2011
    361
    Saint,
    Here is the part file with some sample toolpath on it using 3x pro. I created the pocket by creating a plane out of the base extrude of the pocket, rotating the plane 3 degrees and then extract the edge of the base geometry and offsetting it relative to the plane to create a plane long enough. I then used cross section to create the plane, extended the sides out to make sure the plane fully intersected the geometry, and used Solid/Split to create the general pocket profile. From there, I deleted the lower section of the base pocket that was unnecessary, along with the plane used for splitting. I then used Solid/Subtract to subtract the pocket with the angled bottom from the base guitar body. After that, I used advanced rough with adaptive to handle the roughing, to mimic the original pocket toolpath used, along with project curves as the finish, using the inner wall as the curve.
  17. #17
    Jul 2017
    16
    Sorry I made a mistake it is a 1 degree angle on the bottom of the pocket. Also the CAM tree failed when I tried to open the file. I am using BobCad Standard.
  18. #18
    Jul 2016
    660
    This is what the code looks like partially since I dont have the exact measurements yet, I just set it to 400mm
    First one is the top of the guitar. Drill thru the material first, that`s where you zero your bit, one on the top (15mm) and one on the bottom (15mm) so that when you flip it over you need to align first your two drilled holes using the bit of your router with the two holes.
    Code:
    ( T6 : 6.0 )G21 G90 G91.1 G64 G40
    G0 Z10.0
    ( T6 : 6.0 )
    T6 M6
    ( Guitar Top Outline )
    G17
    M3 S1000
    G0 X18.4496 Y-29.5001
    G0 Z1.0
    G1 F1000.0 Z-3.0888
    G1 X69.36 Y-30.3235
    G1 X69.6862 Y-30.3327
    G1 X69.9924 Y-30.349
    G1 X70.2981 Y-30.3727
    G1 X70.6031 Y-30.404
    G1 X70.9073 Y-30.4427
    G1 X71.2104 Y-30.4889
    G1 X71.5123 Y-30.5426
    G1 X71.8128 Y-30.6036
    G1 X72.1116 Y-30.672
    G1 X72.4088 Y-30.7477
    G1 X72.7039 Y-30.8307
    G1 X72.9534 Y-30.9075
    G1 X74.9461 Y-31.6381
    G1 X76.8316 Y-32.5086
    G1 X78.6404 Y-33.529
    G1 X80.3607 Y-34.6926
    G1 X81.981 Y-35.9917
    G1 X83.4907 Y-37.4177
    G1 X84.88 Y-38.9614
    G1 X86.1397 Y-40.6126
    G1 X87.2614 Y-42.3603
    G1 X88.2379 Y-44.1932
    G1 X89.0627 Y-46.0992
    G1 X89.7537 Y-48.1342
    G1 X90.7868 Y-51.5825
    G1 X91.4555 Y-55.0169
    G1 X91.7823 Y-58.5006
    G1 X91.764 Y-61.9995
    G1 X91.4007 Y-65.4795
    G1 X90.6961 Y-68.9067
    G1 X89.6569 Y-72.2478
    G1 X88.2933 Y-75.4701
    G1 X86.6186 Y-78.5422
    G1 X84.6491 Y-81.4342
    G1 X82.404 Y-84.1179
    G1 X79.8136 Y-86.6569
    G1 X79.2113 Y-87.225
    G1 X78.5836 Y-87.8229
    G1 X77.9588 Y-88.4239
    G1 X77.337 Y-89.028
    G1 X76.7182 Y-89.6351
    G1 X76.1024 Y-90.2452
    G1 X75.4896 Y-90.8584
    G1 X74.8798 Y-91.4746
    G1 X74.2731 Y-92.0938
    G1 X73.6695 Y-92.716
    G1 X73.0689 Y-93.3412
    G1 X72.4428 Y-93.9993
    G1 X71.507 Y-95.0455
    G1 X70.6189 Y-96.3022
    G1 X69.8802 Y-97.6522
    G1 X69.3007 Y-99.0778
    G1 X68.8878 Y-100.5603
    G1 X68.6472 Y-102.0802
    G1 X68.5818 Y-103.6177
    G1 X68.6926 Y-105.1525
    G1 X68.978 Y-106.6647
    G1 X69.4345 Y-108.1343
    G1 X70.0559 Y-109.5421
    G1 X70.8074 Y-110.8242
    G1 X71.1879 Y-111.3662
    G1 X71.5623 Y-111.8472
    G1 X71.9598 Y-112.3093
    G1 X72.3797 Y-112.7512
    G1 X72.8207 Y-113.1719
    G1 X73.282 Y-113.5704
    G1 X73.7622 Y-113.9457
    G1 X74.2604 Y-114.297
    G1 X74.7753 Y-114.6233
    G1 X75.3055 Y-114.9238
    G1 X75.85 Y-115.1979
    G1 X76.4081 Y-115.4453
    G1 X78.5833 Y-116.2825
    G1 X80.7987 Y-117.0094
    G1 X83.0479 Y-117.6239
    G1 X85.3252 Y-118.1244
    G1 X87.6248 Y-118.5096
    G1 X89.9409 Y-118.7786
    G1 X92.2675 Y-118.9307
    G1 X94.5989 Y-118.9655
    G1 X96.9291 Y-118.8829
    G1 X99.2522 Y-118.683
    G1 X101.5622 Y-118.3666
    G1 X102.4603 Y-118.1971
    G1 X103.8334 Y-117.938
    G1 X107.6817 Y-117.0604
    G1 X111.4871 Y-116.0919
    G1 X115.2671 Y-115.0284
    G1 X119.0192 Y-113.8706
    G1 X122.7413 Y-112.6194
    G1 X126.4308 Y-111.2753
    G1 X130.0856 Y-109.8394
    G1 X133.7032 Y-108.3124
    G1 X137.2816 Y-106.6954
    G1 X140.8183 Y-104.9894
    G1 X144.3113 Y-103.1954
    G1 X147.663 Y-101.3665
    G1 X152.5353 Y-98.9697
    G1 X157.5385 Y-97.1576
    G1 X162.71 Y-95.9042
    G1 X167.9876 Y-95.2244
    G1 X173.308 Y-95.1265
    G1 X178.6071 Y-95.6115
    G1 X183.8212 Y-96.6738
    G1 X188.8877 Y-98.3004
    G1 X193.7457 Y-100.472
    G1 X198.3368 Y-103.1623
    G1 X202.6058 Y-106.339
    G1 X206.6178 Y-110.0723
    G1 X213.6112 Y-116.7248
    G1 X221.0589 Y-123.0363
    G1 X228.8566 Y-128.9099
    G1 X236.9785 Y-134.3262
    G1 X245.398 Y-139.2674
    G1 X254.0871 Y-143.7173
    G1 X263.0173 Y-147.6611
    G1 X272.1592 Y-151.0859
    G1 X281.4826 Y-153.9803
    G1 X290.9567 Y-156.3349
    G1 X300.5504 Y-158.1417
    G1 X305.6218 Y-158.7982
    G1 X310.2814 Y-159.4014
    G1 X323.2625 Y-159.9251
    G1 X336.2694 Y-158.7377
    G1 X340.4423 Y-157.794
    G1 X349.0087 Y-155.8567
    G1 X361.2609 Y-151.3318
    G1 X372.8148 Y-145.241
    G1 X383.4713 Y-137.6893
    G1 X393.0469 Y-128.8068
    G1 X401.3764 Y-118.7465
    G1 X408.3163 Y-107.6818
    G1 X413.7472 Y-95.8034
    G1 X417.5753 Y-83.316
    G1 X419.7351 Y-70.4327
    G1 X420.1011 Y-59.4956
    G1 X420.4012 Y-48.7615
    G1 X420.6421 Y-38.026
    G1 X420.8238 Y-27.2893
    G1 X420.9463 Y-16.5518
    G1 X421.0096 Y-5.8138
    G1 X421.0137 Y4.9245
    G1 X420.9587 Y15.6626
    G1 X420.8444 Y26.4002
    G1 X420.671 Y37.137
    G1 X420.4384 Y47.8727
    G1 X420.1469 Y58.5959
    G1 X420.0564 Y62.0966
    G1 X419.872 Y65.638
    G1 X419.595 Y69.1734
    G1 X419.2254 Y72.7002
    G1 X418.7636 Y76.2162
    G1 X418.2098 Y79.7189
    G1 X417.5645 Y83.2059
    G1 X416.8282 Y86.6748
    G1 X416.0012 Y90.1233
    G1 X415.0842 Y93.5488
    G1 X414.0777 Y96.9492
    G1 X412.9847 Y100.3155
    G1 X408.0198 Y114.5381
    G1 X400.9341 Y128.0599
    G1 X391.9465 Y140.3996
    G1 X381.2504 Y151.2918
    G1 X369.076 Y160.5021
    G1 X355.6852 Y167.8323
    G1 X341.3661 Y173.1247
    G1 X340.5283 Y173.3008
    G1 X326.4268 Y176.2653
    G1 X311.1888 Y177.1868
    G1 X305.6483 Y176.7067
    G1 X295.9799 Y175.8691
    G1 X281.1274 Y172.3407
    G1 X267.0973 Y166.7359
    G1 X260.5745 Y163.7503
    G1 X254.1772 Y160.5623
    G1 X247.8889 Y157.1644
    G1 X241.7163 Y153.5604
    G1 X235.6664 Y149.7543
    G1 X229.7456 Y145.7502
    G1 X223.9604 Y141.5525
    G1 X218.3172 Y137.1657
    G1 X212.8222 Y132.5948
    G1 X207.4814 Y127.8446
    G1 X202.3005 Y122.9204
    G1 X197.2967 Y117.8392
    G1 X194.2631 Y114.6134
    G1 X191.0642 Y111.859
    G1 X187.5936 Y109.4557
    G1 X183.8898 Y107.4303
    G1 X183.4131 Y107.2315
    G1 X179.9937 Y105.8052
    G1 X175.9485 Y104.5982
    G1 X171.7989 Y103.8227
    G1 X167.5908 Y103.4874
    G1 X163.3708 Y103.5959
    G1 X159.1855 Y104.1471
    G1 X155.0813 Y105.1348
    G1 X151.1009 Y106.549
    G1 X150.2851 Y106.938
    G1 X149.3234 Y107.3996
    G1 X148.3629 Y107.8636
    G1 X147.4036 Y108.33
    G1 X146.4454 Y108.7989
    G1 X145.4885 Y109.2701
    G1 X144.5327 Y109.7438
    G1 X143.5781 Y110.2199
    G1 X142.6247 Y110.6984
    G1 X141.6726 Y111.1793
    G1 X140.7216 Y111.6626
    G1 X139.7195 Y112.175
    G1 X136.6651 Y113.6083
    G1 X133.6085 Y114.9756
    G1 X130.5276 Y116.2872
    G1 X127.4234 Y117.5426
    G1 X124.2969 Y118.7416
    G1 X121.1492 Y119.8837
    G1 X117.9814 Y120.9685
    G1 X114.7943 Y121.9957
    G1 X111.5892 Y122.965
    G1 X108.367 Y123.8759
    G1 X105.1288 Y124.7283
    G1 X102.4795 Y125.3745
    G1 X101.8513 Y125.5277
    G1 X100.8154 Y125.7436
    G1 X99.8062 Y125.9384
    G1 X98.7942 Y126.1181
    G1 X97.7796 Y126.2828
    G1 X96.7627 Y126.4323
    G1 X95.7437 Y126.5667
    G1 X94.7229 Y126.686
    G1 X93.7003 Y126.79
    G1 X92.6763 Y126.8788
    G1 X91.6511 Y126.9524
    G1 X90.625 Y127.0107
    G1 X89.4383 Y127.0605
    G1 X82.8579 Y126.5852
    G1 X76.3804 Y125.463
    G1 X70.0462 Y123.7035
    G1 X63.9179 Y121.3239
    G1 X58.0562 Y118.3478
    G1 X52.5187 Y114.8045
    G1 X47.3604 Y110.7291
    G1 X42.632 Y106.1617
    G1 X38.3804 Y101.1476
    G1 X34.6474 Y95.7363
    G1 X31.47 Y89.9811
    G1 X28.9286 Y84.0533
    G1 X28.1228 Y82.0521
    G1 X27.3565 Y80.0418
    G1 X26.6278 Y78.0175
    G1 X25.9368 Y75.98
    G1 X25.2839 Y73.93
    G1 X24.6693 Y71.8682
    G1 X24.0931 Y69.7953
    G1 X23.5556 Y67.7121
    G1 X23.057 Y65.6192
    G1 X22.5974 Y63.5174
    G1 X22.177 Y61.4074
    G1 X21.7737 Y59.1659
    G1 X21.5932 Y56.9512
    G1 X21.3824 Y54.9329
    G1 X21.1255 Y52.9198
    G1 X20.8229 Y50.9131
    G1 X20.4746 Y48.9139
    G1 X20.0808 Y46.9231
    G1 X19.6417 Y44.9418
    G1 X19.1575 Y42.971
    G1 X18.6285 Y41.0118
    G1 X18.0551 Y39.0652
    G1 X17.4373 Y37.1321
    G1 X16.8012 Y35.2876
    G1 X16.5494 Y34.6978
    G1 X16.2573 Y33.9338
    G1 X15.9945 Y33.1593
    G1 X15.7616 Y32.3753
    G1 X15.5588 Y31.5829
    G1 X15.3865 Y30.7834
    G1 X15.2448 Y29.9778
    G1 X15.1341 Y29.1675
    G1 X15.0544 Y28.3535
    G1 X15.0058 Y27.537
    G1 X14.9886 Y26.7193
    G1 X15.001 Y25.9907
    G1 X14.999 Y-25.9931
    G1 X15.0225 Y-26.3564
    G1 X15.113 Y-26.8163
    G1 X15.2622 Y-27.2606
    G1 X15.4675 Y-27.6819
    G1 X15.7255 Y-28.0732
    G1 X16.0319 Y-28.4278
    G1 X16.3815 Y-28.7399
    G1 X16.7685 Y-29.0043
    G1 X17.1865 Y-29.2164
    G1 X17.6283 Y-29.3727
    G1 X18.0867 Y-29.4706
    G1 X18.4496 Y-29.5001
    S1000
    G1 Z-6.1776
    G1 X69.36 Y-30.3235
    G1 X84.88 Y-38.9614
    G1 X77.337 Y-89.028
    G1 X420.671 Y37.137
    G1 X419.872 Y65.638
    G1 X340.5881 Y173.2882
    G1 X93.7003 Y126.79
    G1 X31.47 Y89.9811
    G1 X25.9368 Y75.98
    G1 X25.2839 Y73.93
    G1 X23.057 Y65.6192
    G1 X22.177 Y61.4074
    G1 X19.1575 Y42.971
    G1 X15.0058 Y27.537
    G1 X15.001 Y25.9907
    S1000
    G1 Z-9.2664
    G1 X69.36 Y-30.3235
    G1 X84.88 Y-38.9614
    G1 X77.337 Y-89.028
    G1 X420.671 Y37.137
    G1 X419.872 Y65.638
    G1 X340.6479 Y173.2756
    G1 X93.7003 Y126.79
    G1 X31.47 Y89.9811
    G1 X25.9368 Y75.98
    G1 X25.2839 Y73.93
    G1 X23.057 Y65.6192
    G1 X22.177 Y61.4074
    G1 X19.1575 Y42.971
    G1 X15.0058 Y27.537
    G1 X15.001 Y25.9907
    S1000
    G1 Z-12.3552
    G1 X15.001 Y25.9907
    G1 X15.0058 Y27.537
    G1 X19.1575 Y42.971
    G1 X22.177 Y61.4074
    G1 X23.057 Y65.6192
    G1 X25.2839 Y73.93
    G1 X25.9368 Y75.98
    G1 X31.47 Y89.9811
    G1 X93.7003 Y126.79
    G1 X340.7078 Y173.263
    G1 X419.872 Y65.638
    G1 X420.671 Y37.137
    G1 X77.337 Y-89.028
    G1 X84.88 Y-38.9614
    G1 X69.36 Y-30.3235
    S1000
    G1 Z-15.444
    G1 X15.001 Y25.9907
    G1 X15.0058 Y27.537
    G1 X19.1575 Y42.971
    G1 X22.177 Y61.4074
    G1 X23.057 Y65.6192
    G1 X25.2839 Y73.93
    G1 X25.9368 Y75.98
    G1 X31.47 Y89.9811
    G1 X93.7003 Y126.79
    G1 X340.7676 Y173.2505
    G1 X419.872 Y65.638
    G1 X420.671 Y37.137
    G1 X77.337 Y-89.028
    G1 X84.88 Y-38.9614
    G1 X69.36 Y-30.3235
    S1000
    G1 Z-18.5328
    G1 X69.36 Y-30.3235
    G1 X84.88 Y-38.9614
    G1 X77.337 Y-89.028
    G1 X420.671 Y37.137
    G1 X419.872 Y65.638
    G1 X340.8275 Y173.2379
    G1 X93.7003 Y126.79
    G1 X31.47 Y89.9811
    G1 X25.9368 Y75.98
    G1 X25.2839 Y73.93
    G1 X23.057 Y65.6192
    G1 X22.177 Y61.4074
    G1 X19.1575 Y42.971
    G1 X15.0058 Y27.537
    G1 X15.001 Y25.9907
    S1000
    G1 Z-21.6216
    G1 X69.36 Y-30.3235
    G1 X84.88 Y-38.9614
    G1 X77.337 Y-89.028
    G0 Z10.0
    G0 X137.2816 Y-106.6954
    G0 Z-17.5328
    G1 Z-21.6216
    G0 Z10.0
    G0 X340.4423 Y-157.794
    G0 Z-17.5328
    G1 Z-21.6216
    G1 X420.671 Y37.137
    G1 X419.872 Y65.638
    G1 X340.8873 Y173.2253
    G0 Z10.0
    G0 X305.6483 Y176.7067
    G0 Z-17.5328
    G1 Z-21.6216
    G0 Z10.0
    G0 X102.4795 Y125.3745
    G0 Z-17.5328
    G1 Z-21.6216
    G1 X93.7003 Y126.79
    G1 X31.47 Y89.9811
    G1 X25.9368 Y75.98
    G1 X25.2839 Y73.93
    G1 X23.057 Y65.6192
    G1 X22.177 Y61.4074
    G1 X19.1575 Y42.971
    G1 X15.0058 Y27.537
    G1 X15.001 Y25.9907
    ( Pick-up Pocket 1 )
    S1000
    G0 Z10.0
    G0 X114.6953 Y-26.5453
    G0 Z1.0
    G1 Z-3.1993
    G1 X114.6952 Y30.4079
    G1 X119.3211 Y30.4085
    G1 X119.3215 Y-26.5446
    G1 X114.6953 Y-26.5453
    G0 Z10.0
    G0 X111.5024 Y-29.7386
    G0 Z1.0
    G1 Z-3.1993
    G1 X122.5145 Y-29.7371
    G1 X122.514 Y33.6019
    G1 X111.5022 Y33.6003
    G1 X111.5024 Y-29.7386
    G0 Z10.0
    G0 X108.3443 Y-32.8972
    G0 Z1.0
    G1 Z-3.1993
    G1 X125.6726 Y-32.8948
    G1 X125.6721 Y36.7604
    G1 X108.3441 Y36.758
    G1 X108.3443 Y-32.8972
    G0 Z10.0
    G0 X105.1301 Y-36.1118
    G0 Z1.0
    G1 Z-3.1993
    G1 X105.1299 Y39.9718
    G1 X128.8862 Y39.9751
    G1 X128.8868 Y-36.1085
    G1 X105.1301 Y-36.1118
    G1 X105.0087 Y-39.2813
    G1 X104.5179 Y-39.249
    G1 X104.1397 Y-39.1736
    G1 X103.7746 Y-39.0493
    G1 X103.4289 Y-38.8783
    G1 X103.1086 Y-38.6635
    G1 X102.8192 Y-38.4086
    G1 X102.5656 Y-38.1181
    G1 X102.3521 Y-37.7969
    G1 X102.1826 Y-37.4505
    G1 X102.0599 Y-37.0849
    G1 X101.986 Y-36.7063
    G1 X101.9554 Y-36.209
    G1 X101.9723 Y40.0807
    G1 X102.0035 Y40.5757
    G1 X102.0778 Y40.9538
    G1 X102.2009 Y41.3189
    G1 X102.3707 Y41.6648
    G1 X102.5843 Y41.9855
    G1 X102.8379 Y42.2756
    G1 X103.1273 Y42.53
    G1 X103.4475 Y42.7443
    G1 X103.793 Y42.915
    G1 X104.1578 Y43.039
    G1 X104.5357 Y43.1143
    G1 X105.0261 Y43.1465
    G1 X129.0077 Y43.1446
    G1 X129.4985 Y43.1123
    G1 X129.8767 Y43.0368
    G1 X130.2418 Y42.9125
    G1 X130.5874 Y42.7415
    G1 X130.9077 Y42.5267
    G1 X131.1972 Y42.2719
    G1 X131.4508 Y41.9813
    G1 X131.6642 Y41.6601
    G1 X131.8337 Y41.3137
    G1 X131.9565 Y40.9481
    G1 X132.0303 Y40.5696
    G1 X132.0609 Y40.0723
    G1 X132.0441 Y-36.2306
    G1 X132.012 Y-36.7195
    G1 X131.9368 Y-37.097
    G1 X131.8132 Y-37.4612
    G1 X131.643 Y-37.8062
    G1 X131.4293 Y-38.126
    G1 X131.1756 Y-38.4152
    G1 X130.8864 Y-38.6688
    G1 X130.5666 Y-38.8824
    G1 X130.2216 Y-39.0526
    G1 X129.8573 Y-39.1762
    G1 X129.48 Y-39.2512
    G1 X128.9905 Y-39.2832
    S1000
    G0 Z10.0
    G0 Z-2.1993
    G1 Z-6.3986
    G0 Z10.0
    G0 Z-2.1993
    G1 Z-6.3986
    G0 Z10.0
    G0 Z-2.1993
    G1 Z-6.3986
    G0 Z10.0
    G0 Z-2.1993
    G1 Z-6.3986
    G1 X103.1273 Y42.53
    G1 X103.793 Y42.915
    S1000
    G0 Z10.0
    G0 Z-5.3986
    G1 Z-9.5979
    G0 Z10.0
    G0 Z-5.3986
    G1 Z-9.5979
    G0 Z10.0
    G0 Z-5.3986
    G1 Z-9.5979
    G0 Z10.0
    G0 Z-5.3986
    G1 Z-9.5979
    G1 X103.1273 Y42.53
    G1 X103.793 Y42.915
    S1000
    G0 Z10.0
    G0 Z-8.5979
    G1 Z-12.7973
    G0 Z10.0
    G0 Z-8.5979
    G1 Z-12.7973
    G0 Z10.0
    G0 Z-8.5979
    G1 Z-12.7973
    G0 Z10.0
    G0 Z-8.5979
    G1 Z-12.7973
    G1 X103.793 Y42.915
    G1 X103.1273 Y42.53
    S1000
    G0 Z10.0
    G0 Z-11.7973
    G1 Z-15.9966
    G0 Z10.0
    G0 Z-11.7973
    G1 Z-15.9966
    G0 Z10.0
    G0 Z-11.7973
    G1 Z-15.9966
    G0 Z10.0
    G0 Z-11.7973
    G1 Z-15.9966
    G1 X103.1273 Y42.53
    G1 X103.793 Y42.915
    S1000
    G0 Z10.0
    G0 Z-14.9966
    G1 Z-19.1959
    G0 Z10.0
    G0 Z-14.9966
    G1 Z-19.1959
    G0 Z10.0
    G0 Z-14.9966
    G1 Z-19.1959
    G0 Z10.0
    G0 Z-14.9966
    G1 Z-19.1959
    G1 X103.1273 Y42.53
    G1 X103.793 Y42.915
    S1000
    G0 Z10.0
    G0 Z-18.1959
    G1 Z-22.3952
    G0 Z10.0
    G0 Z-18.1959
    G1 Z-22.3952
    G0 Z10.0
    G0 Z-18.1959
    G1 Z-22.3952
    G0 Z10.0
    G0 Z-18.1959
    G1 Z-22.3952
    G1 X103.1273 Y42.53
    G1 X103.793 Y42.915
    S1000
    G0 Z10.0
    G0 Z-21.3952
    G1 Z-25.5945
    G0 Z10.0
    G0 Z-21.3952
    G1 Z-25.5945
    G0 Z10.0
    G0 Z-21.3952
    G1 Z-25.5945
    G0 Z10.0
    G0 Z-21.3952
    G1 Z-25.5945
    G1 X103.1273 Y42.53
    G1 X103.793 Y42.915
    S1000
    G0 Z10.0
    G0 Z-24.5945
    G1 Z-28.7938
    G0 Z10.0
    G0 Z-24.5945
    G1 Z-28.7938
    G0 Z10.0
    G0 Z-24.5945
    G1 Z-28.7938
    G0 Z10.0
    G0 Z-24.5945
    G1 Z-28.7938
    G1 X103.793 Y42.915
    G1 X103.1273 Y42.53
    ( Pick-up Pocket 2 )
    S1000
    G0 Z10.0
    G0 X218.5941 Y-26.5525
    G0 Z1.0
    G1 Z-3.1993
    G1 X218.5936 Y30.4007
    G1 X213.9677 Y30.4001
    G1 X213.9679 Y-26.5531
    G1 X218.5941 Y-26.5525
    G0 Z10.0
    G0 X221.787 Y-29.7449
    G0 Z1.0
    G1 Z-3.1993
    G1 X210.775 Y-29.7465
    G1 X210.7748 Y33.5925
    G1 X221.7865 Y33.594
    G1 X221.787 Y-29.7449
    G0 Z10.0
    G0 X224.9451 Y-32.9026
    G0 Z1.0
    G1 Z-3.1993
    G1 X207.6169 Y-32.905
    G1 X207.6167 Y36.7502
    G1 X224.9446 Y36.7526
    G1 X224.9451 Y-32.9026
    G0 Z10.0
    G0 X228.1594 Y-36.1164
    G0 Z1.0
    G1 Z-3.1993
    G1 X228.1588 Y39.9672
    G1 X204.4025 Y39.9639
    G1 X204.4027 Y-36.1196
    G1 X228.1594 Y-36.1164
    G1 X231.3167 Y-36.2384
    G1 X231.2845 Y-36.7273
    G1 X231.2094 Y-37.1048
    G1 X231.0857 Y-37.469
    G1 X230.9156 Y-37.814
    G1 X230.7018 Y-38.1338
    G1 X230.4482 Y-38.423
    G1 X230.159 Y-38.6766
    G1 X229.8391 Y-38.8903
    G1 X229.4941 Y-39.0604
    G1 X229.1299 Y-39.184
    G1 X228.7526 Y-39.259
    G1 X228.263 Y-39.2911
    G1 X204.2813 Y-39.2892
    G1 X203.7904 Y-39.2569
    G1 X203.4122 Y-39.1814
    G1 X203.0472 Y-39.0571
    G1 X202.7015 Y-38.8861
    G1 X202.3812 Y-38.6713
    G1 X202.0917 Y-38.4165
    G1 X201.8381 Y-38.1259
    G1 X201.6247 Y-37.8047
    G1 X201.4552 Y-37.4583
    G1 X201.3324 Y-37.0927
    G1 X201.2586 Y-36.7142
    G1 X201.228 Y-36.2168
    G1 X201.2449 Y40.0728
    G1 X201.2761 Y40.5679
    G1 X201.3504 Y40.946
    G1 X201.4735 Y41.3111
    G1 X201.6433 Y41.657
    G1 X201.8568 Y41.9777
    G1 X202.1105 Y42.2677
    G1 X202.3999 Y42.5221
    G1 X202.7201 Y42.7365
    G1 X203.0655 Y42.9072
    G1 X203.4303 Y43.0312
    G1 X203.8082 Y43.1065
    G1 X204.2986 Y43.1386
    G1 X228.2802 Y43.1367
    G1 X228.771 Y43.1044
    G1 X229.1492 Y43.029
    G1 X229.5143 Y42.9047
    G1 X229.86 Y42.7337
    G1 X230.1803 Y42.5189
    G1 X230.4697 Y42.264
    G1 X230.7233 Y41.9735
    G1 X230.9368 Y41.6523
    G1 X231.1063 Y41.3059
    G1 X231.229 Y40.9403
    G1 X231.3029 Y40.5618
    G1 X231.3335 Y40.0645
    S1000
    G0 Z10.0
    G0 Z-2.1993
    G1 Z-6.3986
    G0 Z10.0
    G0 Z-2.1993
    G1 Z-6.3986
    G0 Z10.0
    G0 Z-2.1993
    G1 Z-6.3986
    G0 Z10.0
    G0 Z-2.1993
    G1 Z-6.3986
    G1 X229.86 Y42.7337
    S1000
    G0 Z10.0
    G0 Z-5.3986
    G1 Z-9.5979
    G0 Z10.0
    G0 Z-5.3986
    G1 Z-9.5979
    G0 Z10.0
    G0 Z-5.3986
    G1 Z-9.5979
    G0 Z10.0
    G0 Z-5.3986
    G1 Z-9.5979
    G1 X229.86 Y42.7337
    S1000
    G0 Z10.0
    G0 Z-8.5979
    G1 Z-12.7973
    G0 Z10.0
    G0 Z-8.5979
    G1 Z-12.7973
    G0 Z10.0
    G0 Z-8.5979
    G1 Z-12.7973
    G0 Z10.0
    G0 Z-8.5979
    G1 Z-12.7973
    G1 X229.86 Y42.7337
    S1000
    G0 Z10.0
    G0 Z-11.7973
    G1 Z-15.9966
    G0 Z10.0
    G0 Z-11.7973
    G1 Z-15.9966
    G0 Z10.0
    G0 Z-11.7973
    G1 Z-15.9966
    G0 Z10.0
    G0 Z-11.7973
    G1 Z-15.9966
    G1 X229.86 Y42.7337
    S1000
    G0 Z10.0
    G0 Z-14.9966
    G1 Z-19.1959
    G0 Z10.0
    G0 Z-14.9966
    G1 Z-19.1959
    G0 Z10.0
    G0 Z-14.9966
    G1 Z-19.1959
    G0 Z10.0
    G0 Z-14.9966
    G1 Z-19.1959
    G1 X229.86 Y42.7337
    S1000
    G0 Z10.0
    G0 Z-18.1959
    G1 Z-22.3952
    G0 Z10.0
    G0 Z-18.1959
    G1 Z-22.3952
    G0 Z10.0
    G0 Z-18.1959
    G1 Z-22.3952
    G0 Z10.0
    G0 Z-18.1959
    G1 Z-22.3952
    G1 X229.86 Y42.7337
    S1000
    G0 Z10.0
    G0 Z-21.3952
    G1 Z-25.5945
    G0 Z10.0
    G0 Z-21.3952
    G1 Z-25.5945
    G0 Z10.0
    G0 Z-21.3952
    G1 Z-25.5945
    G0 Z10.0
    G0 Z-21.3952
    G1 Z-25.5945
    G1 X229.86 Y42.7337
    S1000
    G0 Z10.0
    G0 Z-24.5945
    G1 Z-28.7938
    G0 Z10.0
    G0 Z-24.5945
    G1 Z-28.7938
    G0 Z10.0
    G0 Z-24.5945
    G1 Z-28.7938
    G0 Z10.0
    G0 Z-24.5945
    G1 Z-28.7938
    G1 X229.86 Y42.7337
    G0 Z10.0
    G0 X0 Y0
    M5
    M30
    This is the bottom of the guitar when you flip it over, I created 4 tabs on it in order for the material not to move and create disaster while you`re working, just use a hack saw blade to free it when you`re done machining
    Code:
    G0 Z10.0
    ( T6 : 6.0 )
    T6 M6
    ( Guitar Outline )
    G17
    M3 S1000
    G0 X15.001 Y25.9919
    G0 Z1.0
    G1 F1000.0 Z-3.0888
    G1 X15.0246 Y26.3552
    G1 X15.1151 Y26.8151
    G1 X15.2643 Y27.2594
    G1 X15.4696 Y27.6807
    G1 X15.7277 Y28.0719
    G1 X16.0341 Y28.4266
    G1 X16.3838 Y28.7387
    G1 X16.7708 Y29.0029
    G1 X17.1888 Y29.215
    G1 X17.6307 Y29.3713
    G1 X18.089 Y29.4692
    G1 X18.4519 Y29.4986
    G1 X69.3624 Y30.318
    G1 X69.6886 Y30.3272
    G1 X69.9948 Y30.3435
    G1 X70.3005 Y30.3672
    G1 X70.6055 Y30.3984
    G1 X70.9097 Y30.4372
    G1 X71.2128 Y30.4833
    G1 X71.5147 Y30.5369
    G1 X71.8152 Y30.5979
    G1 X72.1141 Y30.6663
    G1 X72.4112 Y30.742
    G1 X72.7064 Y30.8249
    G1 X72.9559 Y30.9017
    G1 X74.9486 Y31.6322
    G1 X76.8342 Y32.5025
    G1 X78.6431 Y33.5228
    G1 X80.3634 Y34.6862
    G1 X81.9838 Y35.9852
    G1 X83.4937 Y37.4111
    G1 X84.8831 Y38.9547
    G1 X86.1429 Y40.6058
    G1 X87.2648 Y42.3534
    G1 X88.2414 Y44.1863
    G1 X89.0664 Y46.0922
    G1 X89.7575 Y48.1271
    G1 X90.7909 Y51.5753
    G1 X91.4599 Y55.0097
    G1 X91.7869 Y58.4933
    G1 X91.7689 Y61.9922
    G1 X91.4059 Y65.4723
    G1 X90.7015 Y68.8996
    G1 X89.6626 Y72.2407
    G1 X88.2992 Y75.4631
    G1 X86.6248 Y78.5354
    G1 X84.6555 Y81.4275
    G1 X82.4106 Y84.1114
    G1 X79.8205 Y86.6506
    G1 X79.2182 Y87.2187
    G1 X78.5905 Y87.8167
    G1 X77.9658 Y88.4177
    G1 X77.344 Y89.0219
    G1 X76.7253 Y89.629
    G1 X76.1095 Y90.2392
    G1 X75.4968 Y90.8525
    G1 X74.8871 Y91.4687
    G1 X74.2804 Y92.088
    G1 X73.6768 Y92.7102
    G1 X73.0762 Y93.3354
    G1 X72.4502 Y93.9936
    G1 X71.5145 Y95.0399
    G1 X70.6265 Y96.2967
    G1 X69.8879 Y97.6467
    G1 X69.3085 Y99.0723
    G1 X68.8958 Y100.5548
    G1 X68.6552 Y102.0748
    G1 X68.59 Y103.6123
    G1 X68.7009 Y105.1471
    G1 X68.9865 Y106.6592
    G1 X69.443 Y108.1288
    G1 X70.0645 Y109.5366
    G1 X70.8162 Y110.8187
    G1 X71.1967 Y111.3606
    G1 X71.5711 Y111.8416
    G1 X71.9687 Y112.3036
    G1 X72.3886 Y112.7455
    G1 X72.8297 Y113.1662
    G1 X73.2909 Y113.5646
    G1 X73.7712 Y113.9399
    G1 X74.2694 Y114.2911
    G1 X74.7843 Y114.6174
    G1 X75.3146 Y114.9179
    G1 X75.8591 Y115.1919
    G1 X76.4172 Y115.4393
    G1 X78.5924 Y116.2763
    G1 X80.8079 Y117.003
    G1 X83.0572 Y117.6173
    G1 X85.3345 Y118.1177
    G1 X87.6341 Y118.5027
    G1 X89.9502 Y118.7715
    G1 X92.2769 Y118.9234
    G1 X94.6083 Y118.958
    G1 X96.9385 Y118.8752
    G1 X99.2615 Y118.6752
    G1 X101.5716 Y118.3585
    G1 X102.4696 Y118.189
    G1 X103.8427 Y117.9298
    G1 X107.691 Y117.0519
    G1 X111.4963 Y116.0831
    G1 X115.2762 Y115.0193
    G1 X119.0282 Y113.8612
    G1 X122.7502 Y112.6097
    G1 X126.4396 Y111.2653
    G1 X130.0942 Y109.8291
    G1 X133.7118 Y108.3019
    G1 X137.29 Y106.6846
    G1 X140.8266 Y104.9783
    G1 X144.3194 Y103.184
    G1 X147.671 Y101.3548
    G1 X152.5431 Y98.9576
    G1 X157.5461 Y97.1452
    G1 X162.7175 Y95.8913
    G1 X167.9951 Y95.2111
    G1 X173.3155 Y95.1128
    G1 X178.6146 Y95.5974
    G1 X183.8288 Y96.6593
    G1 X188.8955 Y98.2855
    G1 X193.7536 Y100.4567
    G1 X198.3449 Y103.1466
    G1 X202.6142 Y106.323
    G1 X206.6265 Y110.056
    G1 X213.6204 Y116.708
    G1 X221.0686 Y123.0188
    G1 X228.8667 Y128.8918
    G1 X236.9891 Y134.3075
    G1 X245.4089 Y139.2481
    G1 X254.0985 Y143.6973
    G1 X263.029 Y147.6404
    G1 X272.1711 Y151.0644
    G1 X281.4947 Y153.9581
    G1 X290.9691 Y156.3119
    G1 X300.5628 Y158.118
    G1 X305.6343 Y158.7741
    G1 X310.294 Y159.3769
    G1 X323.2751 Y159.8996
    G1 X336.282 Y158.7111
    G1 X340.4547 Y157.7671
    G1 X349.021 Y155.8291
    G1 X361.2729 Y151.3033
    G1 X372.8263 Y145.2116
    G1 X383.4822 Y137.659
    G1 X393.057 Y128.7757
    G1 X401.3857 Y118.7148
    G1 X408.3248 Y107.6496
    G1 X413.7547 Y95.7708
    G1 X417.5819 Y83.283
    G1 X419.7406 Y70.3996
    G1 X420.1058 Y59.4624
    G1 X420.405 Y48.7284
    G1 X420.6451 Y37.9928
    G1 X420.8259 Y27.2561
    G1 X420.9476 Y16.5186
    G1 X421.0101 Y5.7805
    G1 X421.0133 Y-4.9577
    G1 X420.9574 Y-15.6958
    G1 X420.8423 Y-26.4334
    G1 X420.668 Y-37.1702
    G1 X420.4346 Y-47.9059
    G1 X420.1422 Y-58.6291
    G1 X420.0515 Y-62.1298
    G1 X419.8668 Y-65.6711
    G1 X419.5895 Y-69.2065
    G1 X419.2196 Y-72.7333
    G1 X418.7575 Y-76.2493
    G1 X418.2035 Y-79.7519
    G1 X417.558 Y-83.2389
    G1 X416.8213 Y-86.7077
    G1 X415.9941 Y-90.1561
    G1 X415.0768 Y-93.5816
    G1 X414.0701 Y-96.9819
    G1 X412.9768 Y-100.3481
    G1 X408.0108 Y-114.5703
    G1 X400.924 Y-128.0915
    G1 X391.9354 Y-140.4306
    G1 X381.2385 Y-151.3219
    G1 X369.0633 Y-160.5312
    G1 X355.6719 Y-167.8604
    G1 X341.3524 Y-173.1516
    G1 X341.2926 Y-173.1642
    G1 X326.4129 Y-176.2911
    G1 X311.1748 Y-177.2113
    G1 X305.6343 Y-176.7309
    G1 X295.966 Y-175.8924
    G1 X281.1138 Y-172.3629
    G1 X267.0841 Y-166.757
    G1 X260.5615 Y-163.7709
    G1 X254.1645 Y-160.5823
    G1 X247.8765 Y-157.184
    G1 X241.7042 Y-153.5795
    G1 X235.6545 Y-149.7729
    G1 X229.7341 Y-145.7683
    G1 X223.9492 Y-141.5701
    G1 X218.3064 Y-137.183
    G1 X212.8118 Y-132.6116
    G1 X207.4713 Y-127.861
    G1 X202.2908 Y-122.9364
    G1 X197.2874 Y-117.8547
    G1 X194.2541 Y-114.6287
    G1 X191.0553 Y-111.874
    G1 X187.5849 Y-109.4705
    G1 X183.8813 Y-107.4449
    G1 X183.4046 Y-107.246
    G1 X179.9854 Y-105.8194
    G1 X175.9403 Y-104.6121
    G1 X171.7907 Y-103.8363
    G1 X167.5827 Y-103.5006
    G1 X163.3626 Y-103.6088
    G1 X159.1773 Y-104.1597
    G1 X155.073 Y-105.147
    G1 X151.0925 Y-106.5609
    G1 X150.2767 Y-106.9499
    G1 X149.315 Y-107.4114
    G1 X148.3544 Y-107.8753
    G1 X147.395 Y-108.3417
    G1 X146.4368 Y-108.8104
    G1 X145.4798 Y-109.2816
    G1 X144.524 Y-109.7552
    G1 X143.5694 Y-110.2312
    G1 X142.616 Y-110.7096
    G1 X141.6638 Y-111.1904
    G1 X140.7128 Y-111.6737
    G1 X139.7107 Y-112.1861
    G1 X136.6561 Y-113.6191
    G1 X133.5994 Y-114.9861
    G1 X130.5184 Y-116.2975
    G1 X127.4141 Y-117.5527
    G1 X124.2875 Y-118.7514
    G1 X121.1398 Y-119.8933
    G1 X117.9718 Y-120.9779
    G1 X114.7847 Y-122.0048
    G1 X111.5795 Y-122.9738
    G1 X108.3572 Y-123.8845
    G1 X105.119 Y-124.7366
    G1 X102.4696 Y-125.3826
    G1 X101.8414 Y-125.5357
    G1 X100.8055 Y-125.7516
    G1 X99.7962 Y-125.9463
    G1 X98.7842 Y-126.1259
    G1 X97.7697 Y-126.2905
    G1 X96.7528 Y-126.44
    G1 X95.7338 Y-126.5743
    G1 X94.7129 Y-126.6934
    G1 X93.6903 Y-126.7974
    G1 X92.6663 Y-126.8862
    G1 X91.6411 Y-126.9597
    G1 X90.615 Y-127.0179
    G1 X89.4283 Y-127.0676
    G1 X82.8479 Y-126.5917
    G1 X76.3705 Y-125.4691
    G1 X70.0364 Y-123.709
    G1 X63.9084 Y-121.3289
    G1 X58.0468 Y-118.3523
    G1 X52.5097 Y-114.8086
    G1 X47.3516 Y-110.7328
    G1 X42.6236 Y-106.1651
    G1 X38.3724 Y-101.1507
    G1 X34.6398 Y-95.739
    G1 X31.4629 Y-89.9836
    G1 X28.922 Y-84.0556
    G1 X28.1164 Y-82.0544
    G1 X27.3502 Y-80.0439
    G1 X26.6216 Y-78.0196
    G1 X25.9308 Y-75.982
    G1 X25.2781 Y-73.932
    G1 X24.6636 Y-71.8701
    G1 X24.0876 Y-69.7972
    G1 X23.5503 Y-67.7139
    G1 X23.0518 Y-65.621
    G1 X22.5924 Y-63.5191
    G1 X22.1722 Y-61.4091
    G1 X21.769 Y-59.1677
    G1 X21.5887 Y-56.9529
    G1 X21.378 Y-54.9345
    G1 X21.1214 Y-52.9215
    G1 X20.8189 Y-50.9148
    G1 X20.4707 Y-48.9155
    G1 X20.0771 Y-46.9247
    G1 X19.6381 Y-44.9433
    G1 X19.1541 Y-42.9725
    G1 X18.6253 Y-41.0133
    G1 X18.052 Y-39.0666
    G1 X17.4344 Y-37.1335
    G1 X16.7984 Y-35.2889
    G1 X16.5467 Y-34.6991
    G1 X16.2546 Y-33.9351
    G1 X15.9919 Y-33.1606
    G1 X15.7591 Y-32.3765
    G1 X15.5564 Y-31.5841
    G1 X15.3841 Y-30.7846
    G1 X15.2425 Y-29.979
    G1 X15.1318 Y-29.1687
    G1 X15.0521 Y-28.3547
    G1 X15.0037 Y-27.5382
    G1 X14.9865 Y-26.7205
    G1 X14.999 Y-25.9919
    G1 X15.001 Y25.9919
    G0 Z10.0
    G0 X15.0 Y0.0
    G0 Z1.0
    G1 Z0.0
    G1 X0.0
    ( Guitar Outline )
    S1000
    G0 Z10.0
    G0 X15.001 Y25.9919
    G0 Z-2.0888
    G1 Z-6.1776
    G1 X341.2327 Y-173.1767
    G1 X68.59 Y103.6123
    G1 X74.2804 Y92.088
    G1 X76.7253 Y89.629
    G1 X77.344 Y89.0219
    G1 X72.4112 Y30.742
    G1 X69.3624 Y30.318
    G1 X18.089 Y29.4692
    G1 X17.1888 Y29.215
    G1 X15.001 Y25.9919
    ( Guitar Outline )
    S1000
    G1 Z-9.2664
    G1 X17.1888 Y29.215
    G1 X18.089 Y29.4692
    G1 X69.3624 Y30.318
    G1 X72.4112 Y30.742
    G1 X77.344 Y89.0219
    G1 X76.7253 Y89.629
    G1 X74.2804 Y92.088
    G1 X68.59 Y103.6123
    G1 X341.1729 Y-173.1893
    G1 X15.001 Y25.9919
    ( Guitar Outline )
    S1000
    G1 Z-12.3552
    G1 X17.1888 Y29.215
    G1 X18.089 Y29.4692
    G1 X69.3624 Y30.318
    G1 X72.4112 Y30.742
    G1 X77.344 Y89.0219
    G1 X76.7253 Y89.629
    G1 X74.2804 Y92.088
    G1 X68.59 Y103.6123
    G1 X341.113 Y-173.2019
    G1 X15.001 Y25.9919
    ( Guitar Outline )
    S1000
    G1 Z-15.444
    G0 Z10.0
    G0 X136.6561 Y-113.6191
    G0 Z-11.3552
    G1 Z-15.444
    G0 Z10.0
    G0 X340.8736 Y-173.2522
    G0 Z1.0
    G1 Z-15.444
    G1 X341.0532 Y-173.2145
    G0 Z10.0
    G0 X305.6343 Y158.7741
    G0 Z-11.3552
    G1 Z-15.444
    G0 Z10.0
    G0 X102.4696 Y118.189
    G0 Z-11.3552
    G1 Z-15.444
    G1 X68.59 Y103.6123
    G1 X74.2804 Y92.088
    G1 X76.7253 Y89.629
    G1 X77.344 Y89.0219
    G1 X72.4112 Y30.742
    G1 X69.3624 Y30.318
    G1 X18.089 Y29.4692
    G1 X17.1888 Y29.215
    G1 X15.001 Y25.9919
    ( Guitar Outline )
    S1000
    G1 Z-18.5328
    G0 Z10.0
    G0 Z-14.444
    G1 Z-18.5328
    G0 Z10.0
    G0 X340.9933 Y-173.2271
    G0 Z1.0
    G1 Z-18.5328
    G0 Z10.0
    G0 Z-14.444
    G1 Z-18.5328
    G0 Z10.0
    G0 Z-14.444
    G1 Z-18.5328
    G1 X68.59 Y103.6123
    G1 X74.2804 Y92.088
    G1 X76.7253 Y89.629
    G1 X77.344 Y89.0219
    G1 X72.4112 Y30.742
    G1 X69.3624 Y30.318
    G1 X18.089 Y29.4692
    G1 X17.1888 Y29.215
    G1 X15.001 Y25.9919
    ( Guitar Outline )
    S1000
    G1 Z-21.6216
    G0 Z10.0
    G0 Z-17.5328
    G1 Z-21.6216
    G0 Z10.0
    G0 X340.9335 Y-173.2396
    G0 Z1.0
    G1 Z-21.6216
    G0 Z10.0
    G0 Z-17.5328
    G1 Z-21.6216
    G0 Z10.0
    G0 Z-17.5328
    G1 Z-21.6216
    G1 X68.59 Y103.6123
    G1 X74.2804 Y92.088
    G1 X76.7253 Y89.629
    G1 X77.344 Y89.0219
    G1 X72.4112 Y30.742
    G1 X69.3624 Y30.318
    G1 X18.089 Y29.4692
    G1 X17.1888 Y29.215
    G1 X15.001 Y25.9919
    ( Neck Holder Pocket )
    S1000
    G0 Z10.0
    G0 X56.478 Y-2.4225
    G0 Z1.0
    G1 Z-3.0888
    G1 X54.7718 Y-1.8462
    G1 X47.0243 Y-1.7215
    G1 Y-2.2863
    G1 X56.478 Y-2.4225
    G1 X58.4715 Y-0.4815
    G1 X55.8906 Y1.2431
    G1 X43.8341 Y1.0545
    G1 X43.8339 Y-4.8609
    G1 X62.5526 Y-5.1621
    G1 Y-2.3886
    G1 X61.8667 Y-2.1558
    G1 X60.0743 Y2.2946
    G1 X57.2792 Y4.1622
    G1 X56.9403 Y4.4585
    G1 X40.6356 Y4.2034
    G1 X40.6352 Y-8.0084
    G1 X65.7512 Y-8.4127
    G1 Y-0.0965
    G1 X63.0934 Y0.8057
    G1 X60.0743 Y2.2946
    G1 X61.7002 Y5.1107
    G1 X59.2568 Y6.7433
    G1 X58.1371 Y7.7225
    G1 X37.3909 Y7.3979
    G1 X37.3902 Y-11.2015
    G1 X68.9961 Y-11.7101
    G1 Y2.492
    G1 X67.1227 Y2.8646
    G1 X64.3378 Y3.81
    G1 X61.7002 Y5.1107
    G1 X63.2852 Y7.8561
    G1 X65.551 Y6.7387
    G1 X67.9432 Y5.9267
    G1 X70.4209 Y5.4339
    G1 X72.1593 Y5.303
    G1 Y-14.9247
    G1 X34.2268 Y-14.3142
    G1 X34.2278 Y10.5121
    G1 X59.3037 Y10.9044
    G1 X61.1847 Y9.2596
    G1 X63.2852 Y7.8561
    G1 X64.8909 Y10.6372
    G1 X66.7799 Y9.7056
    G1 X68.7743 Y9.0286
    G1 X70.84 Y8.6177
    G1 X72.5226 Y8.5074
    G1 X75.3638
    G1 Y-18.1812
    G1 X31.0222 Y-17.4675
    G1 X31.0235 Y13.6668
    G1 X60.7356 Y14.1316
    G1 X61.5561 Y13.196
    G1 X63.1396 Y11.8073
    G1 X66.482 Y13.393
    G1 X65.0768 Y14.3319
    G1 X63.8063 Y15.4462
    G1 X62.692 Y16.7167
    G1 X62.2976 Y17.307
    G1 X61.8776
    G1 X27.8482 Y16.7947
    G1 X27.8467 Y-20.5922
    G1 X78.5391 Y-21.408
    G1 Y11.6828
    G1 X72.6266
    G1 X71.2554 Y11.7727
    G1 X69.5979 Y12.1023
    G1 X67.9976 Y12.6456
    G1 X66.482 Y13.393
    G1 X68.1097 Y16.2123
    G1 X69.2434 Y15.6532
    G1 X70.4405 Y15.2468
    G1 X71.6803 Y15.0002
    G1 X72.7329 Y14.9312
    G1 X81.4131
    G1 X81.6417 Y14.9162
    G1 X81.6801 Y14.9059
    G1 X81.7144 Y14.8861
    G1 X81.7425 Y14.8581
    G1 X81.7623 Y14.8237
    G1 X81.7726 Y14.7854
    G1 X81.7876 Y14.5567
    G1 Y-24.7092
    G1 X24.5982 Y-23.7887
    G1 X24.5999 Y19.9946
    G1 X64.1579 Y20.5901
    G1 X64.5724 Y19.7496
    G1 X65.2747 Y18.6985
    G1 X66.1082 Y17.7481
    G1 X67.0586 Y16.9146
    G1 X69.7237 Y19.0078
    G1 X69.0237 Y19.4755
    G1 X68.3907 Y20.0306
    G1 X67.8357 Y20.6636
    G1 X67.3679 Y21.3636
    G1 X66.9956 Y22.1186
    G1 X66.725 Y22.9158
    G1 X66.5607 Y23.7415
    G1 X66.5531 Y23.8577
    G1 X66.5507 Y23.8939
    G1 X21.3789 Y23.1669
    G0 Z10.0
    G0 X69.7237 Y19.0078
    G1 Z-3.0888
    G1 X70.4788 Y18.6355
    G1 X71.276 Y18.3649
    G1 X72.1017 Y18.2006
    G1 X72.8384 Y18.1523
    G1 X81.5185
    G1 X82.0631 Y18.1166
    G1 X82.4967 Y18.0304
    G1 X82.9154 Y17.8883
    G1 X83.3119 Y17.6927
    G1 X83.6795 Y17.4471
    G1 X84.0119 Y17.1556
    G1 X84.3035 Y16.8232
    G1 X84.5491 Y16.4555
    G1 X84.7446 Y16.059
    G1 X84.8868 Y15.6404
    G1 X84.973 Y15.2067
    G1 X85.0087 Y14.6622
    G1 Y-25.8569
    G1 X84.9845 Y-26.2227
    G1 X84.9329 Y-26.4794
    G1 X84.8478 Y-26.7272
    G1 X84.7309 Y-26.9615
    G1 X84.5841 Y-27.1784
    G1 X84.4099 Y-27.3741
    G1 X84.2115 Y-27.545
    G1 X83.9923 Y-27.6884
    G1 X83.7561 Y-27.8015
    G1 X83.507 Y-27.8826
    G1 X83.2494 Y-27.93
    G1 X82.8833 Y-27.9484
    G1 X21.3709 Y-26.9583
    G1 X21.3656 Y-26.7081
    G1 X21.377 Y-26.0468
    G0 Z10.0
    G0 X59.2854 Y10.9253
    G0 Z1.0
    G1 Z-3.0888
    S1000
    G0 Z10.0
    G0 X56.478 Y-2.4225
    G0 Z-2.0888
    G1 Z-6.1776
    G1 Y-2.2863
    G1 X56.478 Y-2.4225
    G1 X55.8906 Y1.2431
    G1 X43.8341 Y1.0545
    G1 Y-2.3886
    G1 X60.0743 Y2.2946
    G1 X63.0934 Y0.8057
    G1 X65.7512 Y-0.0965
    G1 Y-8.4127
    G1 X40.6356 Y4.2034
    G1 X56.9403 Y4.4585
    G1 X57.2792 Y4.1622
    G1 X60.0743 Y2.2946
    G1 X61.7002 Y5.1107
    G1 X59.2568 Y6.7433
    G1 X58.1371 Y7.7225
    G1 X37.3909 Y7.3979
    G1 Y2.492
    G1 X67.1227 Y2.8646
    G1 X64.3378 Y3.81
    G1 X61.7002 Y5.1107
    G1 X63.2852 Y7.8561
    G1 X61.1847 Y9.2596
    G1 X59.2854 Y10.9253
    G1 X72.1593 Y-14.9247
    G1 Y5.303
    G1 X70.4209 Y5.4339
    G1 X67.9432 Y5.9267
    G1 X65.551 Y6.7387
    G1 X63.2852 Y7.8561
    G1 X61.5561 Y13.196
    G1 X75.3638 Y-18.1812
    G1 Y8.5074
    G1 X72.5226
    G1 X70.84 Y8.6177
    G1 X68.7743 Y9.0286
    G1 X66.7799 Y9.7056
    G1 X66.482 Y13.393
    G1 X72.6266 Y11.6828
    G1 X78.5391
    G1 Y-21.408
    G1 X61.8776 Y17.307
    G1 X62.2976
    G1 X62.692 Y16.7167
    G1 X66.482 Y13.393
    G1 X81.7876 Y-24.7092
    G1 Y14.5567
    G1 X81.4131 Y14.9312
    G1 X72.7329
    G1 X71.276 Y18.3649
    G1 X81.5185
    G1 X84.7446 Y16.059
    G1 X84.973 Y15.2067
    G1 Y-25.8569
    G1 X83.2494 Y-27.93
    G1 X66.725 Y22.9158
    G0 Z10.0
    G0 X66.5531 Y23.8577
    G1 Z-6.1776
    S1000
    G0 Z10.0
    G0 X56.478 Y-2.4225
    G0 Z-5.1776
    G1 Z-9.2664
    G1 X47.0243 Y-2.2863
    G1 Y-1.7215
    G1 X56.478 Y-2.4225
    G1 X62.5526 Y-2.3886
    G1 Y-5.1621
    G1 X43.8341 Y1.0545
    G1 X55.8906 Y1.2431
    G1 X60.0743 Y2.2946
    G1 X57.2792 Y4.1622
    G1 X56.9403 Y4.4585
    G1 X40.6356 Y4.2034
    G1 Y-0.0965
    G1 X63.0934 Y0.8057
    G1 X60.0743 Y2.2946
    G1 X61.7002 Y5.1107
    G1 X64.3378 Y3.81
    G1 X67.1227 Y2.8646
    G1 X68.9961 Y2.492
    G1 Y-11.7101
    G1 X37.3909 Y7.3979
    G1 X58.1371 Y7.7225
    G1 X59.2568 Y6.7433
    G1 X61.7002 Y5.1107
    G1 X63.2852 Y7.8561
    G1 X61.1847 Y9.2596
    G1 Y5.303
    G1 X70.4209 Y5.4339
    G1 X67.9432 Y5.9267
    G1 X65.551 Y6.7387
    G1 X63.2852 Y7.8561
    G1 X66.7799 Y9.7056
    G1 X68.7743 Y9.0286
    G1 X70.84 Y8.6177
    G1 X72.5226 Y8.5074
    G1 X75.3638
    G1 Y-18.1812
    G1 X61.5561 Y13.196
    G1 X66.482 Y13.393
    G1 X78.5391
    G1 Y-21.408
    G1 X61.8776 Y17.307
    G1 X62.2976
    G1 X62.692 Y16.7167
    G1 X66.482 Y13.393
    G1 Y14.5567
    G1 X72.7329
    G1 X66.725 Y22.9158
    G1 X83.2494 Y-27.93
    G1 X85.0087 Y-25.8569
    G1 Y14.6622
    G1 X84.973 Y15.2067
    G1 X84.7446 Y16.059
    G1 X81.5185 Y18.1523
    G1 X72.8384
    G1 X71.276 Y18.3649
    G0 Z10.0
    G1 Z-9.2664
    G0 Z10.0
    G0 Z-5.1776
    G1 Z-9.2664
    S1000
    G0 Z10.0
    G0 X56.478 Y-2.4225
    G0 Z-8.2664
    G1 Z-12.3552
    G1 Y-2.2863
    G1 X56.478 Y-2.4225
    G1 X55.8906 Y1.2431
    G1 X43.8341 Y1.0545
    G1 Y-2.3886
    G1 X60.0743 Y2.2946
    G1 X63.0934 Y0.8057
    G1 Y-8.4127
    G1 X40.6356 Y4.2034
    G1 X56.9403 Y4.4585
    G1 X57.2792 Y4.1622
    G1 X60.0743 Y2.2946
    G1 X61.7002 Y5.1107
    G1 X59.2568 Y6.7433
    G1 X58.1371 Y7.7225
    G1 X37.3909 Y7.3979
    G1 Y2.492
    G1 X67.1227 Y2.8646
    G1 X64.3378 Y3.81
    G1 X61.7002 Y5.1107
    G1 X63.2852 Y7.8561
    G1 X61.1847 Y9.2596
    G1 Y5.303
    G1 X70.4209 Y5.4339
    G1 X67.9432 Y5.9267
    G1 X65.551 Y6.7387
    G1 X63.2852 Y7.8561
    G1 X61.5561 Y13.196
    G1 Y8.5074
    G1 X72.5226
    G1 X70.84 Y8.6177
    G1 X68.7743 Y9.0286
    G1 X66.7799 Y9.7056
    G1 X66.482 Y13.393
    G1 X62.692 Y16.7167
    G1 X62.2976 Y17.307
    G1 X61.8776
    G1 Y11.6828
    G1 X72.6266
    G1 X66.482 Y13.393
    G1 Y14.5567
    G1 X72.7329
    G1 X71.276 Y18.3649
    G1 X81.5185
    G1 X84.7446 Y16.059
    G1 X84.973 Y15.2067
    G1 Y-25.8569
    G1 X83.2494 Y-27.93
    G1 X66.725 Y22.9158
    G0 Z10.0
    G1 Z-12.3552
    G0 Z10.0
    G0 Z-8.2664
    G1 Z-12.3552
    S1000
    G0 Z10.0
    G0 X56.478 Y-2.4225
    G0 Z-11.3552
    G1 Z-15.444
    G1 Y-1.7215
    G1 X56.478 Y-2.4225
    G1 Y-5.1621
    G1 X43.8341 Y1.0545
    G1 X55.8906 Y1.2431
    G1 X60.0743 Y2.2946
    G1 X57.2792 Y4.1622
    G1 X56.9403 Y4.4585
    G1 X40.6356 Y4.2034
    G1 Y-0.0965
    G1 X63.0934 Y0.8057
    G1 X60.0743 Y2.2946
    G1 X61.7002 Y5.1107
    G1 X64.3378 Y3.81
    G1 X67.1227 Y2.8646
    G1 X68.9961 Y2.492
    G1 Y-11.7101
    G1 X37.3909 Y7.3979
    G1 X58.1371 Y7.7225
    G1 X59.2568 Y6.7433
    G1 X61.7002 Y5.1107
    G1 X63.2852 Y7.8561
    G1 X65.551 Y6.7387
    G1 X67.9432 Y5.9267
    G1 X70.4209 Y5.4339
    G1 X72.1593 Y5.303
    G1 Y-14.9247
    G1 X61.1847 Y9.2596
    G1 X63.2852 Y7.8561
    G1 X61.5561 Y13.196
    G1 Y8.5074
    G1 X72.5226
    G1 X70.84 Y8.6177
    G1 X68.7743 Y9.0286
    G1 X66.7799 Y9.7056
    G1 X66.482 Y13.393
    G1 X62.692 Y16.7167
    G1 X62.2976 Y17.307
    G1 X61.8776
    G1 Y11.6828
    G1 X72.6266
    G1 X66.482 Y13.393
    G1 Y14.5567
    G1 X72.7329
    G1 X71.276 Y18.3649
    G1 X81.5185
    G1 X84.7446 Y16.059
    G1 X84.973 Y15.2067
    G1 Y-25.8569
    G1 X83.2494 Y-27.93
    G1 X66.725 Y22.9158
    G0 Z10.0
    G1 Z-15.444
    S1000
    G0 Z10.0
    G0 X56.478 Y-2.4225
    G0 Z-14.444
    G1 Z-18.5328
    G1 Y-2.2863
    G1 X56.478 Y-2.4225
    G1 Y-5.1621
    G1 X43.8341 Y1.0545
    G1 X55.8906 Y1.2431
    G1 X60.0743 Y2.2946
    G1 X57.2792 Y4.1622
    G1 X56.9403 Y4.4585
    G1 X40.6356 Y4.2034
    G1 Y-0.0965
    G1 X63.0934 Y0.8057
    G1 X60.0743 Y2.2946
    G1 X61.7002 Y5.1107
    G1 X59.2568 Y6.7433
    G1 X58.1371 Y7.7225
    G1 X37.3909 Y7.3979
    G1 Y2.492
    G1 X67.1227 Y2.8646
    G1 X64.3378 Y3.81
    G1 X61.7002 Y5.1107
    G1 X63.2852 Y7.8561
    G1 X61.1847 Y9.2596
    G1 Y5.303
    G1 X70.4209 Y5.4339
    G1 X67.9432 Y5.9267
    G1 X65.551 Y6.7387
    G1 X63.2852 Y7.8561
    G1 X66.7799 Y9.7056
    G1 X68.7743 Y9.0286
    G1 X70.84 Y8.6177
    G1 X72.5226 Y8.5074
    G1 X75.3638
    G1 Y-18.1812
    G1 X61.5561 Y13.196
    G1 X66.482 Y13.393
    G1 X78.5391
    G1 Y-21.408
    G1 X61.8776 Y17.307
    G1 X62.2976
    G1 X62.692 Y16.7167
    G1 X66.482 Y13.393
    G1 Y14.5567
    G1 X72.7329
    G1 X71.276 Y18.3649
    G1 X81.5185
    G1 X84.7446 Y16.059
    G1 X84.973 Y15.2067
    G1 Y-25.8569
    G1 X83.2494 Y-27.93
    G1 X66.725 Y22.9158
    G0 Z10.0
    G1 Z-18.5328
    G0 Z10.0
    G0 Z-14.444
    G1 Z-18.5328
    ( Volume Knob Hole )
    S1000
    G0 Z10.0
    G0 X243.7044 Y73.0681
    G0 Z1.0
    G1 Z0.0
    G1 X244.1068 Y73.3769
    G1 X244.5754 Y73.571
    G1 X245.0783 Y73.6372
    G1 X245.5812 Y73.571
    G1 X246.0498 Y73.3769
    G1 X246.4522 Y73.0681
    G1 X246.761 Y72.6657
    G1 X246.9551 Y72.1971
    G1 X247.0213 Y71.6942
    G1 X246.9551 Y71.1913
    G1 X246.761 Y70.7227
    G1 X246.4522 Y70.3203
    G1 X246.0498 Y70.0116
    G1 X245.5812 Y69.8175
    G1 X245.0783 Y69.7513
    G1 X244.5754 Y69.8175
    G1 X244.1068 Y70.0116
    G1 X243.7044 Y70.3203
    G1 X243.3956 Y70.7227
    G1 X243.2015 Y71.1913
    G1 X243.1353 Y71.6942
    G1 X243.2015 Y72.1971
    G1 X243.3956 Y72.6657
    G1 X243.7044 Y73.0681
    S1000
    G1 Z-2.6176
    S1000
    G1 Z-5.2352
    S1000
    G1 Z-7.8529
    ( Tone Knob Hole )
    S1000
    G0 Z10.0
    G0 X288.1002 Y117.5173
    G1 Z0.0
    G1 X288.5026 Y117.8261
    G1 X288.9712 Y118.0202
    G1 X289.4741 Y118.0864
    G1 X289.977 Y118.0202
    G1 X290.4456 Y117.8261
    G1 X290.848 Y117.5173
    G1 X291.1568 Y117.1149
    G1 X291.3509 Y116.6463
    G1 X291.4171 Y116.1434
    G1 X291.3509 Y115.6406
    G1 X291.1568 Y115.172
    G1 X290.848 Y114.7696
    G1 X290.4456 Y114.4608
    G1 X289.977 Y114.2667
    G1 X289.4741 Y114.2005
    G1 X288.9712 Y114.2667
    G1 X288.5026 Y114.4608
    G1 X288.1002 Y114.7696
    G1 X287.7915 Y115.172
    G1 X287.5974 Y115.6406
    G1 X287.5311 Y116.1434
    G1 X287.5974 Y116.6463
    G1 X287.7915 Y117.1149
    G1 X288.1002 Y117.5173
    ( Tone Knob Hole )
    S1000
    G1 Z-2.6176
    ( Tone Knob Hole )
    S1000
    G1 Z-5.2352
    ( Tone Knob Hole )
    S1000
    G1 Z-7.8529
    ( Output Socket Hole )
    S1000
    G0 Z10.0
    G0 X319.5436 Y90.3295
    G1 Z0.0
    G1 X319.0137 Y89.639
    G1 X318.6806 Y88.8348
    G1 X318.567 Y87.9718
    G1 X318.6806 Y87.1087
    G1 X319.0137 Y86.3045
    G1 X319.5436 Y85.614
    G1 X320.2342 Y85.0841
    G1 X321.0384 Y84.751
    G1 X321.9014 Y84.6373
    G1 X322.7644 Y84.751
    G1 X323.5686 Y85.0841
    G1 X324.2592 Y85.614
    G1 X324.7891 Y86.3045
    G1 X325.1222 Y87.1087
    G1 X325.2358 Y87.9718
    G1 X325.1222 Y88.8348
    G1 X324.7891 Y89.639
    G1 X324.2592 Y90.3295
    G1 X323.5686 Y90.8594
    G1 X322.7644 Y91.1925
    G1 X321.9014 Y91.3062
    G1 X321.0384 Y91.1925
    G1 X320.2342 Y90.8594
    G1 X319.5436 Y90.3295
    S1000
    G1 Z-2.6176
    S1000
    G1 Z-5.2352
    S1000
    G1 Z-7.8529
    ( Middle String holder Hatch )
    S1000
    G0 Z10.0
    G0 X272.7625 Y-20.1978
    G0 Z1.0
    G1 Z-1.4857
    G1 Y16.3127
    G1 X273.6733
    G1 Y-20.1978
    G1 X272.7625
    G1 X272.1851 Y-23.3913
    G1 X276.8669
    G1 Y19.5063
    G1 X272.1851
    G1 X269.5689 Y18.9292
    G1 Y-22.8142
    G1 X271.8322 Y-26.6299
    G1 X280.1055
    G1 Y22.7449
    G1 X271.8322
    G1 X266.3303 Y21.5313
    G1 Y-25.4163
    G1 X271.4823 Y-29.8404
    G1 X264.3623 Y-28.2699
    G1 X263.1198
    G1 Y24.3848
    G1 X264.3623
    G1 X271.4823 Y25.9554
    G1 X283.316
    G1 Y-29.8404
    G1 X271.4823
    G1 X271.1381 Y-32.9981
    G1 X284.4743
    G1 X284.915 Y-32.9693
    G1 X285.143 Y-32.9239
    G1 X285.3631 Y-32.8492
    G1 X285.5715 Y-32.7464
    G1 X285.7648 Y-32.6173
    G1 X285.9396 Y-32.464
    G1 X286.0928 Y-32.2893
    G1 X286.2219 Y-32.096
    G1 X286.2508 Y-32.0374
    G1 X286.3247 Y-31.8875
    G1 X286.3995 Y-31.6674
    G1 X286.4448 Y-31.4395
    G1 X286.4737 Y-30.9988
    G1 Y27.1138
    G1 X286.4448 Y27.5544
    G1 X286.3995 Y27.7824
    G1 X286.3247 Y28.0025
    G1 X286.2219 Y28.211
    G1 X286.0928 Y28.4042
    G1 X285.9396 Y28.579
    G1 X285.7648 Y28.7322
    G1 X285.5715 Y28.8614
    G1 X285.3631 Y28.9642
    G1 X285.143 Y29.0389
    G1 X284.915 Y29.0842
    G1 X284.4743 Y29.1131
    G1 X271.1381
    G1 X264.0182 Y27.5425
    G1 X259.9621
    G1 Y-31.4276
    G1 X264.0182
    G1 X270.7906 Y-36.187
    G1 X263.6707 Y-34.6164
    G1 X256.7732
    G1 Y30.7314
    G1 X263.6707
    G1 X270.7906 Y32.302
    G1 X284.5787
    G1 X285.3321 Y32.2526
    G1 X285.9701 Y32.1257
    G1 X286.586 Y31.9166
    G1 X287.1694 Y31.629
    G1 X287.7102 Y31.2676
    G1 X288.1993 Y30.8387
    G1 X288.6281 Y30.3497
    G1 X288.9895 Y29.8088
    G1 X289.2772 Y29.2255
    G1 X289.4863 Y28.6095
    G1 X289.6132 Y27.9716
    G1 X289.6626 Y27.2182
    G1 Y-31.1032
    G1 X289.6132 Y-31.8566
    G1 X289.4863 Y-32.4945
    G1 X289.2772 Y-33.1105
    G1 X289.1109 Y-33.4478
    G1 X288.9895 Y-33.6939
    G1 X288.6281 Y-34.2347
    G1 X288.1993 Y-34.7237
    G1 X287.7102 Y-35.1526
    G1 X287.1694 Y-35.514
    G1 X286.586 Y-35.8017
    G1 X285.9701 Y-36.0107
    G1 X285.3321 Y-36.1376
    G1 X284.5787 Y-36.187
    G1 X270.7906
    ( Hole )
    S1000
    G0 Z10.0
    G0 X280.2855 Y20.9617
    G0 Z1.0
    G1 Z-1.4857
    G1 Z-2.4857
    ( Hole )
    S1000
    G0 Z10.0
    G0 Y-1.9425
    G0 Z1.0
    G1 Z-1.4857
    G1 Z-2.4857
    ( Hole )
    S1000
    G0 Z10.0
    G0 Y-24.8467
    G0 Z1.0
    G1 Z-1.4857
    G1 Z-2.4857
    ( Slide )
    S1000
    G0 Z10.0
    G0 X264.0317 Y3.416
    G0 Z1.0
    G1 Z-1.4857
    G1 F400.0 X264.0072 Y13.7923 Z-4.1857
    ( String Deep Holes 1 )
    S1000
    G0 Z10.0
    G0 X274.5267 Y25.2808
    G0 Z1.0
    G1 F1000.0 Z-1.4857
    G1 Z-7.6607
    S1000
    G0 Z10.0
    G0 Y14.3915
    G0 Z1.0
    G1 Z-1.4857
    G1 Z-7.6607
    S1000
    G0 Z10.0
    G0 Y3.5021
    G0 Z1.0
    G1 Z-1.4857
    G1 Z-7.6607
    S1000
    G0 Z10.0
    G0 Y-7.3872
    G0 Z1.0
    G1 Z-1.4857
    G1 Z-7.6607
    S1000
    G0 Z10.0
    G0 Y-18.2765
    G0 Z1.0
    G1 Z-1.4857
    G1 Z-7.6607
    S1000
    G0 Z10.0
    G0 Y-29.1658
    G0 Z1.0
    G1 Z-1.4857
    G1 Z-7.6607
    ( String Deep Holes 2 )
    S1000
    G0 Z10.0
    G0 Y25.2808
    G0 Z-6.6607
    G1 Z-7.6607
    G1 Z-13.8357
    S1000
    G0 Z10.0
    G0 Y14.3915
    G0 Z-6.6607
    G1 Z-7.6607
    G1 Z-13.8357
    S1000
    G0 Z10.0
    G0 Y3.5021
    G0 Z-6.6607
    G1 Z-7.6607
    G1 Z-13.8357
    S1000
    G0 Z10.0
    G0 Y-7.3872
    G0 Z-6.6607
    G1 Z-7.6607
    G1 Z-13.8357
    S1000
    G0 Z10.0
    G0 Y-18.2765
    G0 Z-6.6607
    G1 Z-7.6607
    G1 Z-13.8357
    S1000
    G0 Z10.0
    G0 Y-29.1658
    G0 Z-6.6607
    G1 Z-7.6607
    G1 Z-13.8357
    ( String Deep Holes 3 )
    S1000
    G0 Z10.0
    G0 Y25.2808
    G0 Z-12.8357
    G1 Z-13.8357
    G1 Z-20.0107
    S1000
    G0 Z10.0
    G0 Y14.3915
    G0 Z-12.8357
    G1 Z-13.8357
    G1 Z-20.0107
    S1000
    G0 Z10.0
    G0 Y3.5021
    G0 Z-12.8357
    G1 Z-13.8357
    G1 Z-20.0107
    S1000
    G0 Z10.0
    G0 Y-7.3872
    G0 Z-12.8357
    G1 Z-13.8357
    G1 Z-20.0107
    S1000
    G0 Z10.0
    G0 Y-18.2765
    G0 Z-12.8357
    G1 Z-13.8357
    G1 Z-20.0107
    S1000
    G0 Z10.0
    G0 Y-29.1658
    G0 Z-12.8357
    G1 Z-13.8357
    G1 Z-20.0107
    ( String Deep Holes 4 )
    S1000
    G0 Z10.0
    G0 Y25.2808
    G0 Z-19.0107
    G1 Z-20.0107
    G1 Z-26.1857
    S1000
    G0 Z10.0
    G0 Y14.3915
    G0 Z-19.0107
    G1 Z-20.0107
    G1 Z-26.1857
    S1000
    G0 Z10.0
    G0 Y3.5021
    G0 Z-19.0107
    G1 Z-20.0107
    G1 Z-26.1857
    S1000
    G0 Z10.0
    G0 Y-7.3872
    G0 Z-19.0107
    G1 Z-20.0107
    G1 Z-26.1857
    S1000
    G0 Z10.0
    G0 Y-18.2765
    G0 Z-19.0107
    G1 Z-20.0107
    G1 Z-26.1857
    S1000
    G0 Z10.0
    G0 Y-29.1658
    G0 Z-19.0107
    G1 Z-20.0107
    G1 Z-26.1857
    G0 Z10.0
    G0 X0 Y0
    M5
    M30
  19. #19
    Jul 2017
    16
    I have tool paths for everything except the neck pocket. I am using BobCad V29 Standard. I use the wizard for the 3 mill, but I must not be answering something right. I really would like to learn how to properly do this with the wizard, so I can use that knowledge in the future on other pieces.
  20. #20
    Jul 2017
    16
    Just standard
Page 1 of 2 12
  1. Pocket milling with bobcad
    By patracy in forum Tutorials
    Last Post: 03-02-2024, 09:33 AM
  2. Replies: 3
    Last Post: 12-03-2019, 06:30 PM
  3. Radius Wall Pocket BobCAD CAM V28 Mill Pro
    By aldepoalo in forum BobCad-Cam
    Last Post: 03-05-2016, 12:35 AM
  4. Can Bobcad pocket an angle
    By mkhushf in forum BobCad-Cam
    Last Post: 05-28-2015, 02:27 AM
  5. Problem with angled pocket in Partworks 3D
    By eriedel in forum Vectric
    Last Post: 06-12-2013, 08:03 PM
