531,637 active members*
3,860 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Biesse > Need help with creating tabs in biesseworks
    I am looking to cut a bunch of small parts from very light stock on a Biesse Rove Plast J. The shop I work for has very limited resources and knowledge, I think tabs would be the best way to hold the parts down but I don't know if this is something I can do in Biesseworks or even have the designer do in Vector works. Sadly this project is a rush so redesigning is rather limited so on the Vector works side it would have to be simple settings only changes. That said any and all advice is welcome.
    *Registered User*
    Apr 2018
    16
    Re: Need help with creating tabs in biesseworks
    Not sure if it's too late, but adding tabs in BiesseWorks itself is a pain. If you want to add tabs, you can import the files into Aspire or vCarve and simply click the add tabs option.
    Nov 2011
    7
    Unfortunately the tabs function doesn't exist in Biesse works or even in Biesse software generally.
  1. Creating 'holding tabs' or 'bridges'...
    By irwinger in forum Dolphin CAD/CAM
    Last Post: 05-06-2017, 03:43 AM
  2. Creating tabs on a solid part
    By dkrenfrow in forum Mastercam
    Last Post: 04-14-2017, 09:27 PM
  3. Creating tabs in Mastercam x6
    By Stevetotheo in forum Mastercam
    Last Post: 09-17-2013, 03:40 PM
  4. creating biesseworks macros
    By oshaw in forum Commercial CNC Wood Routers
    Last Post: 11-29-2011, 02:15 PM
  5. creating biesseworks macro
    By oshaw in forum CNC Machining Centers
    Last Post: 08-24-2011, 06:24 PM
