525,473 active members*
2,853 visitors online*
Results 1 to 1 of 1
    Jul 2020
    need help with dxf file
    need help with file.
    I am new to cad and designed a file to be cnc cut with a router and I only want it all the lines cut out not the insides so just all line art.
    this forums will not let me attach dxf files????
    Mar 2003
    35012
    Re: need help with dxf file
    Zip the file and attache the .zip file
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Dec 2013
    4378
    That is really a function of your CAM program. Normally the Trace or Engrave function is what you want to use. The actual name of the function is dependent on what CAM program you are using.
    Jim Dawson
    Sandy, Oregon, USA
