544,051 active members*
1,841 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Need Help!!Routech 130 Errror code plc130 needs maintenance conditioner
Results 1 to 5 of 5
    Jul 2016
    Hello. I recently purchased a used record 130. Upon initial start up it is throwing error code plc130-needs maintenance conditioner. Does anyone know how to solve this code?
    Service SCM BR
    Guest
    Re: Need Help!!Routech 130 Errror code plc130 needs maintenance conditioner
    This is the door of electrical cabinet. The switch not work correctly. Verify the switch with the tester.
    Via iPhone of the Tapatalk
    Oct 2020
    The same error appeared in my routech just a couple of hours ago. Couldn't find a problem. Help plz.
    Jun 2020
    Quote Originally Posted by amelianorth View Post
    Have you tried to check out the switch? This error usually happens when it's smth incorrect with the switch itself.
    Jun 2020
    I'm not sure if this information would help, but this error may also occur when there is a variance between the network address of the target (connected device) which has been set to display and your network address which has been set on the connected device. The solution is quite simple, you need to change the target and the network address via settings. You can also search for the info at https://www.socool.sg/ because sometimes they post the info about the common errors. So, if checking out the switch or using this method doesn't help you, then you should definitely call a repair technician.
  1. Replies: 2
    Last Post: 05-16-2013, 06:44 PM
  2. power conditioner or digital phase converter?
    By bherr in forum Benchtop Machines
    Last Post: 09-12-2008, 01:34 AM
  3. phase conditioner
    By MOOG B-22 in forum Phase Converters
    Last Post: 07-22-2007, 02:41 AM
