585,748 active members*
3,712 visitors online*
Results 1 to 14 of 14
    Jan 2012
    Need Laser Engraver Suggestions
    OK, heres the deal. I have a small business manufacturing various small parts mainly out of aluminum. I need to be able to etch my logo on my parts and I'm about to pick up some more work that will also require etching. All of the parts will small in size and quantity to I'm really looking for a smaller entry level machine. Mainly just wanting to keep everything in house as much as possible.
    I was just going to pick up one of the Cheap K-40 models off of ebay but decided not to after reading all of the reviews. I only have around $2k to spend so I'm trying to see what options are out there.
    Any suggestions would be great.
    Jan 2011
    242
    Aluminum is difficult to mark with a laser unless if it's anodized. You can try doing it with Cermark but the results are inconsistent. A used Roland mechanical engraver will probably be your best bet.
    Feb 2012
    387
    aluminum engraving
    Hi there,
    Yes, anodized al can be clean marked by co2 laser machine ,here is two pictures for your refrence
    Best Regards
    Lucy Lee
    G.WEIKE LASER
    [email protected]
    Quote Originally Posted by cbauman79 View Post
    May 2005
    101
    Lucy Lee
    What reci tube's watt is good to only mark on Aluminium (80, 100, 150, ???) ? The Yag or fiber is out of budget.
    Oct 2011
    155
    My 100W RECI will not mark aluminium without Thermark or being anodised.
    May 2005
    101
    Bec Weir
    I also have Grvograph LS600XL of 60 watt. and written on laser tube 80 watt.. It is marking like light red color but not acceptable. I am trying to find cheap from China under $5K.
    Jan 2011
    242
    Quote Originally Posted by Bec Weir View Post
    Even with Thermark/Cermark you have to engrave VERY slowly and the results can be less than ideal.
    If you want to engrave bare aluminum on a small budget, mechanical engraving is the way to go. It's really that simple. If you want to engrave anodized aluminum, any laser will work.
    Feb 2012
    387
    al
    HI,
    If the anodized aluminum, 80w,100w can work
    Best Regards
    Lucy Lee
    G.WEIKE LASER
    [email protected]
    Quote Originally Posted by muqtadir View Post
    Lucy Lee
    May 2005
    101
    My target is aluminium and Steel marking only.
    Rodney , Cape Town , South Africa
    www.tokerbros.co.za
    May 2005
    101
    It is not clear and good quality by the Etch-o-matic and by Cermark etc. I already used them.
    Oct 2011
    155
    What about a template and sand or bead blasting of the logo?
    Dec 2003
    259
    This is diamond drag engraving on stainless steel.
    The circle is 50mm diameter as a guide on size.
    Done on a cheap Roland engraver with the spindle thrown away and replaced by a spring loaded diamond.
    Feb 2013
    Post Re: Suggestion for the laser engraving
    This is not the good engraving on plate....
    The characters are the not looking good and not the proper on the plate....
    Use the effective and appropriate laser engraving machine for it like needham-laser.
    needham-laser.com
  1. got Dahlgren engraver for retrofit- suggestions?
    By lkasdorf in forum DIY CNC Router Table Machines
    Last Post: 09-14-2015, 03:15 PM
  2. wklaser (Gweike laser) 2011 No. 1 Hot Product--6040N laser engraver display
    By Melody-gweike in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-05-2014, 02:25 PM
  3. CNC Laser Engraver, CNC Laser Cutting Machine, Dealer Wanted!!!
    By oliver9866 in forum Engraving Machines
    Last Post: 12-15-2010, 09:44 PM
  4. Replies: 1
    Last Post: 09-07-2009, 04:10 PM
  5. Suggestions for laser engraver around $4000
    By TacPyro in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-05-2009, 12:21 AM
