567,778 active members*
2,579 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Need Some Help - Lift/Jog between cuts
Results 1 to 1 of 1
    Feb 2023
    Hi I am a newb, I need some help with settings that lift the z Axis between cuts also before and after. Tool scrapes surface and I dont know how to adjust. Thanks!
    Aug 2011
    118
    Re: Need Some Help - Lift/Jog between cuts
    Quote Originally Posted by dano72 View Post
    I don't know what CAM software you use, but that is called rapid plane (or cylinder for 4 axis, or sphere for 5 axis) and need to be above stock material.
