586,957 active members*
3,006 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Need some help unlocking the MDI on Haas NG Controller
    May 2013
    170
    I recently purchased a 2018 Haas DM1 with NG Controller, and I'm new to the NG controller ( My DM-2 has the Pre NG )
    So I'm trying to work my way through learning the NG controller, and the first hurdle is trying to unlock the MDI
    Any line of code I key into MDI it says FUNCTION LOCKED.
    Any help would sure be appreciated...
    Thanks,
    Kent
    May 2013
    170
    Re: Need some help unlocking the MDI on Haas NG Controller
    Just a quick update...
    Setting 8 ( Prog Memory Lock ) was turned on from the previous owner..
    Got that turned off and now everything is working like a charm....
  1. Bridgeport VMC 760/22 DX32 controller MDI stopped working
    By Jbf23bkn in forum Bridgeport Machines
    Last Post: 03-14-2023, 06:34 PM
  2. HAAS MDI
    By bthomas7408 in forum Haas Mills
    Last Post: 03-21-2019, 01:42 AM
  3. unlocking cutter comp? 31i a5 controller
    By bmfhart in forum Fanuc
    Last Post: 12-02-2012, 06:46 AM
  4. Unlocking G codes
    By SirDenisNayland in forum Fanuc
    Last Post: 11-14-2011, 08:32 AM
  5. Help with MDI in Fanuc 15-m controller
    By Barnowl in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-06-2009, 06:58 PM
