Re: Needing help/ advise
So it's hard to say but if your beam worked for 4 hours, I'd start with the assumption it's OK (for now).
The pictures of the power supply look to be the one for the Steppers not the laser. Usually the laser power supply is on the other side of the machine. I'd check the connections there. If the connections are OK, then I'd quickly check the controller output (search for how, it's easy enough but basically it's full voltage from controller to laser PS on one wire (usually 5v ish) , then a percentage of that on another wire that matches the power level you've set).
The power supply itself is testable only with a huge resistor that mimics the tube. You can read the low voltage wire (the one from the output side of the tube) in milliamps too and see what the draw is.
Since most lasers don't supply the huge resistor to troubleshoot it's typically easier to buy a new power supply and swap it out.
Either it's the problem or the new one becomes the spare (and they are consumable parts on lasers to some degree).
If the controller is OK and the new power supply is OK, then it's likely the tube. They are pretty simple systems. These 3 parts make the fire so to speak so start with the easy fast and cheap check (control voltage), move to power supply (medium cost but slow to get to you hence the reason to keep a spare) and end with high cost high risk (tube).
Lasers often have set up pains, maybe due damage enroute or humidity or who knows, but once you swap out the offending bits it should go better.
Sent from my LG-D852 using Tapatalk
In case anyone is wondering, I'm the twin of the other gfacer on cnczone...
