554,208 active members*
4,475 visitors online*
IndustryArena Forum > Employment Opportunity / RFQ (Request for Quote). > RFQ (Request for Quote) > USA RFQ's > Needing two 6061 spacers turned from 2.25 OD/ 1.75 ID tubing
    Sep 2007
    179
    I own and run a machine shop however we only manufacture our own products that we produce and sell directly. I need to get a couple extensions turned from 6061 and since our lathe wont accept a 2 inch diameter so I cant do it my self inhouse.
    In the attached pdf file there are two parts, essentially the same part just two lengths.
    I am looking to get one of each made for a total of two parts.
    Machined surface tool finish is fine. Factory extruded surface finish on all non machined surfaces is fine.
    Thanks in advance for your consideration. Please pm or email me at kdc754@gmail.com
    Oct 2021
    8
    Re: Needing two 6061 spacers turned from 2.25 OD/ 1.75 ID tubing
    Hi, I have emailed you, Please send me the drawings.Thank you
    hi,i have sent email.pls check.
  1. RFQ - Simple Turned Steel Spacers
    By LateNight72 in forum USA RFQ's
    Last Post: 02-17-2020, 06:26 PM
  2. RFQ Turned 6061 Parts
    By rxtreme in forum Employment Opportunity
    Last Post: 07-10-2015, 04:20 PM
  3. Deburring of a large qty of turned spacers
    By Pharkas in forum General MetalWork Discussion
    Last Post: 06-27-2012, 03:08 PM
  4. Gash repair- 6061 AL tubing?
    By Scuff in forum Welding Brazing Soldering Sealing
    Last Post: 10-30-2009, 04:28 PM
  5. 6061 SPACERS
    By EDPACECAR in forum Employment Opportunity
    Last Post: 06-03-2009, 04:43 PM
