585,752 active members*
3,736 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > NEW 4 Axis KL-6040T 1.5KW MACH3, Mach4 CNC ROUTER ENGRAVER 110VAC USB Connection
    NEW 4 AXIS KL-6040T 1.5KW MACH3, MACH4 CNC ROUTER ENGRAVER/ENGRAVING 110VAC USB CONNECTION
    Product link:
    https://www.automationtechnologiesin...usb-connection
    https://www.youtube.com/watch?v=zEB53rkT4TE
    You can come to our show room in IL to check the machine
    if you need 220VAC, let us know first
    USA Tech Support (847-984-0882)
    Package include:
    1: 4 Axis 6040T 1.5KW Machine
    2: USB Connection Cable
    X Y Z Working Area: 600(Y) * 390?X?* 120(Z) mm
    Outside dimension: 865*680*570mm?L*W*H)
    Table size: 770?Y?*490?X?mm
    Lathe structure: 6061/6063 Aluminum alloy
    Stepping motor: NEMA23 two-phase 3A
    Power: 1.5KW VFD
    Spindle speed: 24000 rpm
    Max working frequency: 400Hz
    Principal axis collet: ER11collet
    Nut Model: ER11-A
    Cooling: Water-cooling
    Repeat accuracy: 0.05mm
    Computer connection: USB port
    Maximum Idle speed: 0-1500mm/min
    Working Speed: 50-1500mm / min
    Jul 2020
    Re: NEW 4 Axis KL-6040T 1.5KW MACH3, Mach4 CNC ROUTER ENGRAVER 110VAC USB Connection
    nice thanks
  1. Replies: 0
    Last Post: 12-26-2020, 09:03 PM
  2. 4 Axis Stepper Motor CNC Router / Mill Electronics Kit, Gecko G540 (110VAC/220VAC)
    By automationtechinc in forum Automation Technology Products
    Last Post: 06-05-2018, 08:14 PM
  3. 6040-4-AXIS-ENGRAVER-USB-CNC-ROUTER-ENGRAVER
    By RASPER in forum DIY CNC Router Table Machines
    Last Post: 05-04-2018, 08:00 PM
  4. DB25 Parallel Connection to USB on Breakout board for CNC Router
    By robertsonwf in forum USB, RS232, PARALLEL etc
    Last Post: 02-12-2016, 06:12 AM
  5. Replies: 5
    Last Post: 09-04-2014, 12:49 PM
