528,358 active members*
3,254 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > New 6040 E 2.2KW ARF CNC Router Help needed!
Results 1 to 14 of 14
    Sep 2019
    8
    Exclamation New 6040 E 2.2KW ARF CNC Router Help needed!
    Hello,
    I just recently purchased this router, done everything as in instructions (found three versions of them all with bad translation and mistakes). I want to know how to connect the router via ethernet cable to Mach3? Spindle is spinning via VFD box but Mach3 says No FHC USB pod found.
    Mar 2003
    35100
    Re: New 6040 E 2.2KW ARF CNC Router Help needed!
    The box has an ethernet connection? If so, you'll need the correct plugin for whatever ethernet controller it's using. All the ones I've ever seen have been USB.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2019
    8
    Yes, it has only Ethernet connection. What do you mean "correct plugin"?
    Aug 2009
    230
    Mach 3 and 4 use software "plugins" - think of it as sort of a device driver - to communicate with breakout boards via USB or Ethernet. Different breakout boards "speak" different "languages" (so to speak), and Mach needs the correct plugin to communicate with it.
    If the documentation that came with it doesn't indicate which driver plugin you need, you might have to open the case on the electronics box to identify the board.
    Hope that helps...
    Mar 2003
    35100
    Yes. It sounds like you have a plugin installed for a USB controller, not the ethernet controller that you have. Without the correct plugin, Mach3 can't communicate with your controller.
    Gerry
    Sep 2019
    8
    Understood, there are downloaded plugins. I added them to Mach3 but no success at the moment. Seller recommended to change from Windows XP to Windows 7 and then start all over which im doing right now
    Mar 2003
    35100
    That likely won't make any difference.
    Gerry
    Sep 2019
    8
    Possible, as i read XP is better but maybe there are problems with PC drivers
    Mar 2003
    35100
    XP is no better or worse for Mach3, and there are no drivers that would affect Mach3 operation.
    Gerry
    Sep 2019
    8
    Cnaging windows didnt helped, same as XP looks like there is problem with IP configuration or aquiring motion card IP (cant connect PC to router). Maybe someone could explain attached instruction? This is the step where i got stuck:
    https://ibb.co/dLRBD66
    Sep 2019
    8
    Connected the router to PC, at the moment i can move all axis with keyboard except spindle. How can i configure spindle setup? It works only when turned on control box
    Jun 2019
    Did you have any luck getting it running? Thoughts/feedback about the machine?
    Dec 2019
    27
    Maybe the spindle is not connected to the board, in that case you cannot operate it from Mach3 but only from the front panel.
    Inviato dal mio iPhone utilizzando Tapatalk
    Hello,
    This page includes everything needed to run this ARFCNC 6040E CNC machine.
    https://hl-yeah.com/2019/01/08/2019-...th-confidence/
    If has further issue with this machine, please post here.
    Thanks,
  1. Replies: 17
    Last Post: 03-27-2020, 07:58 PM
  2. Backup router needed. 6040 a good option?
    By anthropod in forum Chinese Machines
    Last Post: 04-11-2019, 06:05 PM
  3. 6040 cnc router issues
    By paulsanders in forum Chinese Machines
    Last Post: 06-10-2017, 02:36 PM
  4. 6040 router
    By flewggle in forum Chinese Machines
    Last Post: 01-28-2017, 04:33 AM
  5. chinese 6040 cnc router
    By mrgame1988 in forum Australia, New Zealand Club House
    Last Post: 09-21-2016, 12:41 PM
