527,871 active members*
2,012 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > General Laser Engraving / Cutting Machine Discussion > new 60w Chinese laser suddenly not having full Y axis movement
    Jul 2020
    The laser has been working great. I have added a CloudRay laser combiner. I was aligning the mirrors and
    noticed that I can not get the Y axis to go to the front of the machine. Everything works fine except that it
    will not go past the Y half way point. I connected with Lightburn and had same result.
    Any suggestions ?
    Joe
    Jul 2020
    Re: new 60w Chinese laser suddenly not having full Y axis movement
    Figured it out. I had been testing new rotary attachment. I still had the rotary attachment enabled in lightburn. Once I disabled "Enable Rotary" in Lightburn everything worked fine
