544,016 active members*
2,317 visitors online*
Results 1 to 10 of 10
    Jun 2008
    New AutoGrav website
    Precise and affordable CNC routers and engraving machines made in Germany.
    Have a look: http://www.autograv.com
    Oct 2005
    10
    I have one of these... and I love it! Any other autograv users in this forum?
    Iam doing frontpanels and signs with an autograv AG III:
    Jun 2008
    6
    Hi You.
    i also have a Autograv machine.
    what software do you design your project in.
    regards
    Tomas
    Quote Originally Posted by Roelli View Post
    Oct 2005
    10
    Quote Originally Posted by Tde1806 View Post
    Hi Thomas.
    Where are you from and which machine do you use exactly?
    For designing projects i always use vcarve pro from a company called vectric. This software seams to be made for wood and vcarving... but its really the best software on earth for making signs and frontpanels etc... I'd tested many others but this is very good and cheap compared to the other ones. Ok, its 450€ or so but it really is one of the best buys i ever did.
    If you're using an minimal lubricant (MMKS from Steidle for example) the postprocessor may needs some changes. I can send you my postprocessor which works perfectly with my autograv machine if you want.
    The cncgraf software is really nice but its not a cad/cam and the machine software from other companies don't have all the functions like a real cad/cam software. For example... if you want to use dxf files from corel draw or autocad... the contour is sometimes "broken" in single parts. This will result in problems when using these files directly in cncgraf. But its the same with other programs. So what I did is... I just make everything in vcarve and send the file over ethernet to the autograv computer. I set the XYZ zero points and hit the start button. Work good all the time.
    I bought an autgrav AGIII and its really a nice machine. As good as other machines which are sold for 10.000€. Iam in contact with the guy who makes the software for the machine and the software is getting better and better. Its even better than other programs on the market at the moment. I added a high frequency spindle and a vacuum table to the machine.
    Regards,
    Roelli.
    Oct 2005
    10
    Hey, I'd seen that you wanted to buy a high-Z.
    Congratulations that you didn't bought this machine!
    I wanted to buy exactly this machine in the beginning. But I don't. And that was one of the best decisions I'd made in my hole life!
    Jun 2008
    6
    post processor to cncgraf
    Hi Roelli
    I´m from Denmark, and i have a Autograv IV machine.
    it will be great if you will sent me a copy of your post processor.
    best regards
    Tomas Ebbesen ( Denmark )
    Hi Thomas.
    Regards,
    Roelli.
    Oct 2005
    10
    No problem, just send me an email: autogravpostprocessor@nrgrecording.de
    Frank.
    Aug 2010
    CG-5 Autograv Image. CG-5 Autograv Gravity Meter. CG-5 Autograv Gravity Meter ... gravity meter by upgrading your CG-3 to a CG-5, or trade-in your CG-3 for a new CG-5. ... For more information please see our sister company's Website a
    __________________________________
    Want to get-on Google's first page and loads of traffic to your website? Hire a SEO Specialist from Ocean Groups seo pecialist
    Mar 2008
    6
    Smile Autograv ll
    Hello there
    I just want to tell what i am using with success.
    The Router is an Autograv ll
    I make all drawings in Solid Works 3D and export the files as DXF files.
    I import the DXF file in Vectric's program Cut2D. In Cut2D i setup the material and choose the tool(s) to use and the lines and dept to follow among other impotent things. It is wary easy and logic to use. I save the file(s) for Mach3.
    Mach3 is the program there control the machine from Artsoft. This is the most inexpensive CNC program used all over the world. The is new version on its way.
    Best regards and happy Christmas
    Jørgen
    Jun 2021
    11
    Re: New AutoGrav website
    Its very important article and I should read this article carefully
  1. Autograv cnc machine.
    By Tde1806 in forum Mach Software (ArtSoft software)
    Last Post: 06-01-2021, 04:16 AM
  2. Looking for a website
    By Hack in forum Uncategorised MetalWorking Machines
    Last Post: 09-23-2009, 01:00 AM
  3. Looking for a website for percission parts website
    By FandZ in forum DIY CNC Router Table Machines
    Last Post: 07-01-2009, 03:24 PM
  4. website
    By j-radkemachine in forum Polls
    Last Post: 02-12-2007, 08:45 PM
