585,991 active members*
4,724 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > NEW DESIGN CRASH RESISTANT LOW COST TOUCH PROBE
Page 1 of 6 123
Results 1 to 20 of 117
    Feb 2007
    1538
    Hi Folks.
    I am keen to get your technical feedback on a new Design Touch Probe I have been developing.
    Please note I want to respect the rules of this forum and do not in this posting offer this invention for sale etc. I am interested to receive your technical thoughts and feedback only via this thread.
    Cheers Keen
    https://www.youtube.com/watch?v=f4ARkpeCXX4
    https://www.youtube.com/watch?v=9X2EKattGyY
    May 2008
    77
    Re: NEW DESIGN CRASH RESISTANT LOW COST TOUCH PROBE
    Nice work keen. Not to be pedantic, but wouldn't this be a "crash damage resistant" design, as opposed to "crash resistant". All likeliness of crashing is still there. As seen here
    How easy would it be to change out the shaft if its bent? I watched the videos again, but I didn't see if the probe could measure Z.
    Aug 2007
    701
    Nice - when can I buy one?
    Feb 2007
    1538
    Quote Originally Posted by soymilk View Post
    Thanks for your feedback. Maybe Smash Resistant would be more accurate!
    Yes the Probe measures Z just the same.
    It is unlikely the shaft or stem would break - but if it did, I am thinking it best to supply a replacement stylus assembly. It has a simple design and will help keep the overall cost down.
    Cheers.., Keen
    Feb 2007
    1538
    Quote Originally Posted by brianbonedoc View Post
    Hi Brian. Thanks for the feedback.
    I want to respect the forum rules and not discuss price or supply etc here, this thread is for technical matters.
    You can send me a PM re other matters.
    Cheers Keen
    Apr 2013
    1788
    Does the probe have normally open contacts or normally closed contacts like the Tormach #32309? I ask because several times in the video you mentioned failure due to forgetting to plug in the cable.
    Mar 2008
    216
    Keen:
    The "secret" to having the internal contacts working for millions of cycles without requiring any maintenance is to have electronics that detects when the contacts are about to open and drop the current to zero. This is how the older Renishaw probes operate (I have purchased multiple Renishaw probes on eBay for very low prices). Having a constant current running through the contacts (without the low voltage sensing) will result in arcing when the contacts open up. If you sense the voltage increase before the contacts open, you can reduce the current to zero before the contacts open and totally prevent arcing. This will also greatly increase the sensitivity of the probe since the stylus deflection is greatly reduced as well. A timeout has to occur before a test constant current gets reapplied, and if the contact is still open drop the current to zero again and wait the timeout again. You can often get Renishaw probe interface boxes on eBay for reasonable prices, although you may prefer making your own electronics (that's what I would do in your situation).
    Apr 2013
    1788
    I haven't checked which are expired but Renishaw obtained numerous patents covering their ideas including the arc reduction technique that you mentioned, a breakaway stylus, use of strain gauges, piezo sensors, optical sensors, wireless connections, etc, etc. Something to consider if you decide to commercialize the improved touch probe.
    May 2010
    327
    I really like your style keen. Well done.
    WW
    Manufacturing & Development
    ThermaeCooling.com
    Feb 2014
    72
    I'd certainly be interested in this probe. I use a standard edge finder cause of dealing with expensive probes just hasn't been worth it to me.
    Feb 2007
    1538
    Quote Originally Posted by kstrauss View Post
    Hi kstrauss.
    Normally closed.
    Feb 2007
    1538
    Quote Originally Posted by Dallas J View Post
    Keen
    Feb 2007
    1538
    Quote Originally Posted by Zetopan View Post
    Keen:
    Thanks for that Zetopan.
    The high end Renishaw type probes are very sophisticated, accurate and reliable. But that comes at a high price if purchased new with the warranty.
    The Hallmark Design Probe is much simpler - think of it as an improved Tormach SPU 40 passive probe ..hopefully at about that price point.
    So with that always in mind, I needed to keep the design simple.
    Cheers Keen
    Feb 2007
    1538
    Hi kstrauss. I think I am clear on this but some more checking would not hurt.
    Cheers Keen
    Feb 2007
    1538
    Yes they were also my early thoughts - for practical workshop use you don't need a highly priced delicate instrument. That is why I bought the Tormach SPU 40 - and it was almost good enough .
    Keen
    Jun 2006
    3063
    Have you given any thought to an optional longer probe? I can see where there may be a need for something like once in a while.
  17. #17
    Feb 2006
    7063
    I'm surprised you're getting more love for this here.... My one and only reason for never using that type of probe is I know I would periodically break the !@#$%^&* stylus, and they are always expensive. I really like what you've done, and the improved accuracy is extra gravy. If you can keep it in the same price range as the Tormach probe, I would think you would do very well with this. I'd buy one, and no doubt unintentionally put your "break resistant" claims to the acid test! :-)
    Regards,
    Ray L.
  18. #18
    Feb 2007
    1538
    Quote Originally Posted by MichaelHenry View Post
    Hi Michael.
    Yes there are different versions that could be made - but one step at a time. Cheers
    - - - Updated - - -
    Quote Originally Posted by SCzEngrgGroup View Post
    Regards,
    Ray L.
    Thanks Ray - I appreciate your encouragement.
    Keen
  19. #19
    Apr 2016
    109
    Yes, I am extremely interested in this.
    What kind of tip is on your stylus? It looks like you are putting on a ruby or similar? It's still possible to crash and break it, even with the incredible amount of travel you have built in. You'll need to be very up front about what replacements will cost so people feel at ease with the design.
    It doesn't seem completely necessary for the tip to be anything other than carbide.
    Another thing I've always wondered, what about making a probe that's both conductive and mechanical? Have a mode switch on the side so that when dealing with metals you can use conductive for perfect accuracy and for non-conductive materials use the mechanical mode?
    EDIT - I believe I heard in the video your stylus is ceramic?
  20. #20
    Aug 2015
    368
    I totally agree, I'd like to have one but only if I wouldn't get TOO pissed off when I broke it, I don't need to spend the kind of money most others cost but I'd love to justify the convenience with a lower price. It looks awesome, I have all the faith in the world that if you've made it, especially from the ground up, it's fantastic!
    Sent from my SM-G900V using Tapatalk
Page 1 of 6 123
  1. Another Touch Probe
    By JerryBurks in forum DIY CNC Router Table Machines
    Last Post: 12-02-2021, 09:07 PM
  2. Passive Probe Crash
    By refc91 in forum Tormach PathPilot™
    Last Post: 11-06-2015, 03:32 PM
  3. Replies: 12
    Last Post: 06-05-2013, 06:05 PM
  4. Crash reishaw Probe on Super MiniMill using IPS
    By Gus-Gus in forum Haas Mills
    Last Post: 11-01-2008, 04:16 AM
