Hi There,
I'm in the unfortunate position of setting up a new K2CNC ( KG3925HD-8-TT-ATC using flop, kmotion, kmotionCNC ) that was received shortly after K2 went dark.
The specific problem that we are facing: I can manually rotate the DC servo (powered on) with ease, a few degrees (resulting in 0.010" movement of the X axis).
The servo does seem to re-center itself to the original coordinates, though it does this over fifteen seconds or so.
Without any tech support from K2, We are hoping that someone else has suffered the same issue.
In the Kmotion Configuration, all servos are set to defaults:
Axis Modes: Encoder (input) Step Dir (output)
Input Channels: 0, 1 gain, 0 offset
Output Channels: 0, 1 gain, 0 offset
In the Axis window we can see the manual rotation in the position column, and this is also where we see it return to equal the proper Dest.
I am sure it is as simple a solution, as it might have been in the K2 documentation (had we received any).
Thank you all for you're time. Hope you are well.
Mark Kett
1(905)449-6447
