547,049 active members*
2,409 visitors online*
    Jan 2010
    11
    New to me Torq-Cut 22
    I recently purchased a Tore-Cut 22 at auction. Prior to getting it delivered, I want to build some machine skates so I can move it around the shop during it's refurbishment. Can anyone provide the dimensions of the leveling feet /bolts. Pictures are always welcome
    thanks,
    jdub
    Jan 2010
    11
    Re: New to me Torq-Cut 22
    So I got the machine into the shop and I have single phase power hooked up to it. I haven’t moved any of the axis, just wanted to see the controller boot up. Before I move anything, I need to get the tool carousel moved to the home position. It seems it was powered down (prior to me getting it) with the carousel in the change position. What is the best way to get everything sequenced correctly?
    Attachment 470826
    Jan 2010
    11
    Quick update, I was able to get all the axis and tool changer homed. I'm in the process of cleanup and paint refresh. So far, I've removed two 5 gallon buckets of chips. The enclosure was removed for media blasting, I'll get primer on all the metal parts this week.
    Attachment 471266
    Attachment 471268
  1. Looking at a Torq Cut 22
    By hax0red in forum Bridgeport / Hardinge Mills
    Last Post: 05-12-2020, 03:17 PM
  2. help with torq cut 22
    By christian7r in forum Bridgeport / Hardinge Mills
    Last Post: 05-17-2019, 10:31 PM
  3. Torq cut
    By cooperjm in forum Bridgeport / Hardinge Mills
    Last Post: 10-07-2018, 06:35 PM
  4. TORQ-Cut-22
    By tpmx57 in forum Bridgeport / Hardinge Mills
    Last Post: 08-09-2017, 06:42 AM
  5. Torq cut 22
    By Dirtman in forum Bridgeport / Hardinge Mills
    Last Post: 06-03-2010, 12:53 AM
