504,350 active members
3,683 visitors online
Page 1 of 2 12
Results 1 to 12 of 13
    Question NEWBIE - Pins & Mach3 setup for CNC router
    Hi everyone,
    I bought a used home-made CNC router together with PC. Everything worked fine, sometime later PC went crazy and without much consideration I replaced HDD for SSD and re-installed WINDOWS only to later realize that all the setup in MACH3 was gone. Since I have no knowledge of building CNC and I have no way of contacting previous owner who made this machine, I'm stuck with good non-working CNC.
    I watched some videos, read some articles and tried some pin variations, but no success.
    What I can tell, is I have MD882 board.
    Can anyone help me with setting up this machine again.
    Your help would me very much appreciated.
    Andrew.
    Aug 2016
    177
    Re: NEWBIE - Pins & Mach3 setup for CNC router
    Quote Originally Posted by Andrew_Waldmen View Post
    Hi everyone,
    Andrew.
    Do you have the old HDD still? If so you should be able to connect that drive and get the XML file out of the MACH3 directory.
    Sent from my XT1635-01 using Tapatalk
    Nope, it's wiped!t
    Aug 2016
    177
    Nope, it's wiped!t
    That does suck...
    The board you reference looks to be a motor driver..
    Do you know what breakout board it is. Can you take some pics
    Quote Originally Posted by truckeic View Post
    That does suck...
    Yeah sure.
    Please tell me You understand something here ))
    Attached Thumbnails Attached Thumbnails IMG_20190516_152929.jpg   IMG_20190516_152932.jpg   IMG_20190516_152935.jpg   IMG_20190516_152938.jpg   IMG_20190516_152944.jpg
    Aug 2016
    177
    Yeah sure.
    Ok your control board is a CNC4PC board. I cant see which version should be like C and some numbers. That would help some.
    The last pic you sent shows the motor outs. If you trace the org/wht pairs and the blu/wht pair from the Drivers (Looks like they are labeled X y and Z) back to the board you can figure out motor drives. the white wires are probably +5 volts and the blue is probably step and org is direction. You can look at the driver and verify. The 4 wires bottom right in picture 6 are probably spindle drives. You can trace them to the VFD. If you can get me a closer shot of the rest of the connections I can try and help further...
    You're amazing.
    Ill be in workshop Friday, will take more photos then!
    Aug 2016
    177
    You're amazing.
    Your mill us way more than I have...
    But I have a CNC4PC board a C11G.
    You must have a 3phase spindle. I have jus a DC motor.
    Not amazing folks here helped me lots I only hope I can help..
    Aug 2016
    177
    You're amazing.
    did you take any new pics
    Hi. Yeah, sorry, I did take more pictures. Hope they mean something more. Maybe You need something closer!?
    Mar 2007
    1980
    later to night when I can use my own computer
    I'll download the breakout manual and try to workout which are the step signals and which are the direction signals to the stepper drivers
    I expect in Mach3's ports & pins
    pins 2 to 6 are the step and direction for your 3 axis drivers
    its not easy to see if 7 & 8 are for a 4th axis or possibly control a couple of relays for on/off & direction control of the spindle
    a wide shot of inside of the control box will help
    John
    Aug 2016
    177
    Can you let us know what the model of the board is..
Page 1 of 2 12
  1. newbie question on step by step cutting setup/ process in Mach3
    By Matt Clara in forum Mach Software (ArtSoft software)
    Last Post: 05-27-2014, 07:36 AM
  2. New CNC Router Setup Tool For Use With Mach3
    By CambiumMachines in forum News Announcements
    Last Post: 05-20-2011, 02:47 PM
  3. G201/Mach3, ports and pins setup
    By xander18 in forum Benchtop Machines
    Last Post: 05-15-2011, 07:41 PM
  4. Where am I going wrong with ports and pins setup?
    By phantomcow2 in forum Mach Software (ArtSoft software)
    Last Post: 02-21-2007, 03:27 AM
  5. Pins setup for gecko G 201
    By engraver in forum Mach Software (ArtSoft software)
    Last Post: 07-23-2003, 07:17 AM
