601,652 active members*
2,579 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > No movement C11G, Mach3, UC400eth
    May 2025
    I’m retrofitting an older CNC router with a new control system. I’m using a UC 400 motion controller connected to a C11G breakout board that is connected to four 5056 drivers. Have communication with Mach3, all my outputs on the C11 are enabled with the green LED light illuminated…when I use Mach 3 to jog the system the corresponding output LEDs illuminate, but no motor movement! the motors are “holding” so they obviously are getting power. Drivers are connected properly, pins are set properly in Mach3, but can’t figure out what I’m missing. Motors were working fine with old control system. Any ideas?
    Re: No movement C11G, Mach3, UC400eth
    Quote Originally Posted by gallcorn View Post
    Make sure Mach3 knows what port is feeding each signal.
    Go to Config > Ports and Pins > Motor Outputs
    Enable X/Y/Z/A as needed
    Step Pin and Dir Pin numbers must match the actual pin numbers going from UC400 -> C11G -> 5056.
  1. Mach3 settings for UC400ETH
    By ZeroBacklash in forum Mach Software (ArtSoft software)
    Last Post: 10-01-2018, 10:21 PM
  2. Mach3 with UC400ETH
    By MMC336 in forum Questions or Problems
    Last Post: 08-08-2018, 01:49 AM
  3. install Mach3 help, issue with UC400eth? Please Help
    By originalsigns in forum Mach Mill
    Last Post: 07-20-2017, 01:19 PM
  4. Mach3 UC400eth and joypad
    By silverdog in forum UCCNC Control Software
    Last Post: 04-21-2016, 09:14 AM
  5. UC400ETH and Mach3
    By vmax549 in forum UCCNC Control Software
    Last Post: 04-08-2016, 05:24 AM
