594,860 active members*
4,929 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > HEIDENHAIN > HEIDENHAIN -> TNC > not showing absolute value on screen after applying a tool offset
Results 1 to 6 of 6
    Aug 2007
    230
    Hello, in TNC 426/410, how can I view the absolute value after applying a tool offset? There are three or four position values available, such as actual, reference, distance to go, etc. Unlike Fanuc or other controllers, which display a Z value of zero on the top surface of the workpiece after taking the tool offset, the TNC does not show the absolute value after the tool offset is applied. need to advise. I am using a cam generation software to get G-codes in iso format. please look sample program which is run sucessfully.
    %DRILLING_1 G71
    N1 G40 G90
    N2 G30 G17 X-100 Y-100 Z-75
    N3 G31 G90 X100 Y100 Z3
    N4 G17 T1 M6
    N5 S1000 M3
    N6 G00 X20 Y30
    N7 G00 Z20
    N8 G83 P01 2 P02 -20 PO3 -10 P04 0 PO5 80
    N9 G00 X20 Y30 M89
    N10 G00 X80 Y50 M99
    N11 M5
    N12 M30
    N999999 %DRILLING_1 G71
    regards
    asif
    Re: not showing absolute value on screen after applying a tool offset
    Quote Originally Posted by fsa View Post
    %DRILLING_1 G71
    N1 G40 G90
    N4 G17 T1 M6
    N5 S1000 M3
    N6 G00 X20 Y30
    N7 G00 Z20
    N9 G00 X20 Y30 M89
    N10 G00 X80 Y50 M99
    N11 M5
    N12 M30
    regards
    asif
    Since you’re using cam generation software for G-codes, make sure your offsets are correctly set in the program. Sometimes, the software might handle offsets differently than the controller, so double-check that.
    Aug 2007
    230
    Quote Originally Posted by cncmakers001 View Post
    I don't know what you want to say..I am talking about tool display value on the machine screen when taking tool offset from work piece surface
    Dec 2008
    3185
    Have you tried using Heidenhain coding instead of ISO
    ie... "Toolcall" instead of "M6"
    Our iTNC530 had issues with a Fanuc type of post processor, until a proper Heidenhain post was purchased.
    Aug 2007
    230
    no don't have Heidenhain coding post-processor can you show me the format of your post-processor output codes?
    Dec 2008
    3185
    Probably better to show you from a dedicated site...
    We started to make little scripts in MDI, using the control keyboard. Once starting the command, it would prompt you with correct options to complete the line of command.
    Hopefully, the site gives you a concept to build further.
    https://www.emco-world.com/en/products/industrial-training/softwarecontrols/winnc/heidenhain-tnc-426-430.html
  1. absolute Z value after applying a tool offset TNC 426/410
    By fsa in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 11-17-2024, 12:30 AM
  2. Changing tool diameter in the tool offset screen
    By Vern Smith in forum Haas Mills
    Last Post: 05-09-2022, 05:25 PM
  3. Replies: 1
    Last Post: 01-29-2020, 09:40 AM
  4. Absolute readout & tool length offset
    By leeroy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-29-2019, 11:36 AM
  5. Display Absolute on tool offset page
    By billm in forum Fanuc
    Last Post: 02-14-2007, 09:12 PM
