537,761 active members*
3,479 visitors online*
Results 1 to 7 of 7
    NVEM controller and VFD drive
    Hello all
    I have a NVEM board and i am trying to hook it up to my VFD for spindle control.
    I could not find anything in side the manual from the VFD. I am familiar with the NVEM setup, but the layout on the VFD is what I am not familiar with.
    I was wondering if anyone else had that issue as I did not find any videos or info on it
    Community Moderator
    Dec 2003
    23632
    Re: NVEM controller and VFD drive
    What is the model of the VFD it looks like the PLC is settable for hi or lo logic. DI1 DI2 input etc..
    The BOB has lousy documentation and is not really clear on to I/O? They sort of imply it is settable for hi or lo logic with the word "programmable"
    You should be able to switch the VFD Start with a direct interface to one of the BOB outputs.
    Al.
    Albert E.
    Im not to sure about the brand as it looks to be a knock off but here is the link where i bought it https://www.amazon.de/gp/product/B07...?ie=UTF8&psc=1
    Community Moderator
    Dec 2003
    23632
    The pic looks like Huanyang (see Logo) , but the manual does not?
    Albert E.
    Yeah the manual is not what i seen from others Huanyang manuals. I think theDI1 could be FWD and DI2REVS. But i am not sure abut the V1 or VOI
    Community Moderator
    Dec 2003
    23632
    The manual should show the input assignments, is there any more explanation in the manual that jives with the actual VFD?
    I would contact the supplier if you can and get some clarification!
    Al
    Albert E.
    Gold Member
    Apr 2006
    3494
    worst controller.. I am moved toward RosettaCNC controller...
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
  1. Ethernet Controller which? XHC Ethernet MK4-ET or NVEM ? Or other ?
    By mmiminoo in forum Want To Buy...Need help!
    Last Post: 04-22-2020, 11:31 PM
  2. NVEM 5 Axis CNC Controller Ethernet MACH3
    By cncpc37 in forum Mach Software (ArtSoft software)
    Last Post: 12-03-2019, 09:03 AM
  3. NVEM Ethernet controller driver
    By GraemeT in forum Controller Cards
    Last Post: 02-10-2019, 10:51 AM
  4. NVEM Ethernet controller custom mpg
    By greekart in forum General CNC Machine Related Electronics
    Last Post: 01-11-2018, 07:11 PM
  5. Encoder signal to servo drive & controller; split or through drive?
    By strantor in forum Servo Motors / Drives
    Last Post: 08-21-2017, 04:22 PM
