Hello,
i have a 3D probe that is attached to an extendable arm that is extended and retracted via a stepper motor.
The probe is offset from the spindle by -60mm in x and -20mm in y. Unfortunately I can only set a maximum offset in x and y of -10 under probe & measure.
If I enter the values manually in settings.settings and then open Planet CNC, it sets the values back to x-10 y-10.
How can I hard save the values?
My software version is 2024.08.27
