544,051 active members*
1,882 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma FWRITC command
    Jun 2004
    6
    Post Okuma FWRITC command
    Hi All,
    When writing to a file on the Okuma,
    Is it possible to use a variable within the FWRITE command.
    I'd like to save individual files using a time stamp format
    IE:-
    DATACATCH - 26-05-21
    DATACATCH - 27-05-21
    DATACATCH - 28-05-21
    ETC
    If possible I would assume its something like
    FWRITC MD1 : DATACATCH - {DATE}.TXT;A
    Thanks in advance
    Alan
    Jun 2004
    6
    Re: Okuma FWRITC command
    I've had a further look.
    Can anyone tell me whether the following is the correct syntax for what I'm trying to achieve.
    FWRITC MD1: DATACATCH - [VTIME].TXT;A
    Jun 2015
    3309
    hy what kind of data are you recording ?
    Code:
        FWRITC daily.txt;A
        PUT '    '         ( tab )
        PUT VTIME [ 1 ] , 4
        PUT ' . '
        PUT VTIME [ 2 ] , 2
        PUT ' . '
        PUT VTIME [ 3 ] , 2
        PUT '    '
        PUT VTIME [ 4 ] , 2
        PUT ' . '
        PUT VTIME [ 5 ] , 2
        PUT ' . '
        PUT VTIME [ 6 ] , 2
        WRITE C
        CLOSE C
  1. Replies: 1
    Last Post: 04-08-2016, 02:55 AM
  2. Okuma MX-60HB SVP Speed Command alarm
    By Chinook0 in forum Okuma
    Last Post: 02-04-2015, 09:09 PM
  3. Okuma OSP5000L 2151 Command Error in MDI
    By twicecustom in forum Okuma
    Last Post: 09-03-2012, 08:22 AM
