How do I keep the chip augers from turning on? I only ever want them on when I turn them on manually.
I believe that there is a parameter for the augers that determines if they start automatically or not.
go to your parameters and look for the "Chip Conveyor" section.
You didn't say what control you have, but since it's a Genos, it should have a newer control with that section in the parameters.
Experience is what you get just after you needed it.
hymaybe these are available also on your machine : mc user para \ no 1 coolant \ chip conveyor +
... turn on with coolant [ list item 22; use page up/dn to navigate ]
... turn on with nc run [ 23 ]
... turn off with reset [ 70 ]
... manual select continuance time [ 89 ]
... intermitent stop time [ 97 ]
... stop at alarm d time [ 123 ]
... stoped at alarm a/b [ 143 ]
