535,183 active members*
4,092 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > okuma & howa 2sp v80 fanuc 18t turret alignment
Results 1 to 4 of 4
    Aug 2011
    5
    I need help aligning the left turret on the okuma & howa vtl. I have looked at the book I was given by the owner and I'm not sure that it is correct. I am more of a mill man than lathe. The book says to remove bolts and pins from coupling. I was wondering if ut could be done in the parameters using the hand pulse wheel. Please advise of how to do this. It would be greatly appreciated.
    Gold Member
    Feb 2009
    6028
    Don't know that machine model, but no. All lathes have a coupling or pin to lock in a turret. It's always a mechanical alignment.
    Aug 2011
    5
    This model actually has ten 12mm bolts that actually go up into the coupling. I have checked to make sure there are no pins i only have to adjust it .031. But everytime i make the adjustment it goes right back to where it was. Thank you any more advice on which bolts to remove would be greatly appreciated
    Re: okuma & howa 2sp v80 fanuc 18t turret alignment
    Hello,
    I am desperately in need for the parameters for this machine, PC and PMC or diagnostics. If you could share or sell please let me know
    My email address is JOLULA@yahoo.com
    Thank you
    jolulank
    Quote Originally Posted by brybry-0104 View Post
    www.doctornumerico.com
    cnc physicians
  1. Okuma & Howa Fanuc 6T Help
    By Kevin77 in forum Fanuc
    Last Post: 10-09-2020, 05:15 PM
  2. Okuma Howa Act20 turret index
    By acidav in forum Okuma
    Last Post: 06-07-2014, 11:03 PM
  3. Okuma LNC-8 Turret alignment
    By brandonzp in forum Okuma
    Last Post: 02-26-2013, 02:38 AM
  4. Okuma Howa Turret Loose
    By marklosch in forum Okuma
    Last Post: 11-02-2009, 12:09 PM
  5. Okuma Lathe Turret Alignment
    By herotool in forum Okuma
    Last Post: 06-17-2008, 04:51 PM
