585,761 active members*
4,190 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma LB15 position help
    Apr 2013
    15
    All
    I have an older Okuma LB15 that Im just bringing online and learning to program. Im having trouble with the G00 command. No matter what value I input for the G0 the machine will only go to the zero set position (x0 z0). The machine was originally set up for a bar feeder so im wondering if this is some sort of parameter or something that can be changed? It doesnt matter if the machine is in Auto or MDI, whenever you call up G0 it goes to the Set Zero point
    Apr 2009
    1262
    Re: Okuma LB15 position help
    Are you by chance trying to set positive X and Z positions as if you were "homing" a Fanuc machine? The Okuma's do not have a home, so that could be the issue. If you've done that, you should be able to go into the back of the machine and get out your Management Data card and enter the Zero set numbers and be back in business. The absolute encoders always know where they are even across power off, so not homing is required.You can even power off, move the ballscrew and power up and they still will know where they are.
    The G00 command will take you to the X and Z limits and go no further even if the command is higher.
    X0 is normally set to the center of a boring bar/drill holder and you would drill a hole at X0 with no X tool offset. Z would be set to where your program zero is by moving the turret to where you want Z 0 to be and then pressing CAL 0 Write. You will have odd numbers in your Zero Set registers, but your actual position should show good positions. X zero set is typically recorded on the DMC as well.
    Best regards,
    Experience is what you get just after you needed it.
  1. OKUMA LB15 II MW
    By Bimachine in forum Okuma
    Last Post: 12-12-2019, 02:38 PM
  2. please help about okuma LB15 II MW
    Last Post: 11-24-2019, 02:40 PM
  3. Okuma LB15 z position problem
    By Beefheart in forum Okuma
    Last Post: 08-22-2019, 10:22 PM
  4. okuma LB15
    By NJC in forum Okuma
    Last Post: 04-11-2013, 05:40 AM
  5. okuma LB15 help
    By cbrannam in forum Okuma
    Last Post: 10-09-2011, 12:45 PM
