585,692 active members*
3,609 visitors online*
IndustryArena Forum > CNC Electronics > Hobbycnc (Products) > okuma lb15 wilt osp5000 moves only in one direction
    Nov 2009
    30
    Dear friends,
    I have a cnc okuma lb15 with osp5000 controller, when i try to jog the cnc the z axes moves in both directions but the x axes moves only in one direction.
    the machine is not showing any errors on the controller or on the driver, but the x axes only moves in the negative direction?
    what may cause this and how can i fix it
    Mar 2020
    13
    Re: okuma lb15 wilt osp5000 moves only in one direction
    Hi. We have the same problem. Were you able to solve this?
  1. LB15 OSP5000 CPU error
    By geeserteg in forum Okuma
    Last Post: 12-22-2020, 10:41 PM
  2. Replies: 13
    Last Post: 08-16-2016, 10:52 AM
  3. OKUMA OSP5000
    By neko911 in forum Okuma
    Last Post: 03-04-2012, 03:21 PM
  4. LB15 with OSP5000 monitor
    Last Post: 12-09-2009, 11:20 PM
  5. Okuma Osp5000
    By hien100881 in forum G-Code Programing
    Last Post: 11-28-2007, 05:59 AM
