Re: okuma lb3000 mill/turn, compensations for live tooling making using C-Z Axis ???
hello Lizz do you still need help ?
CZ compensation, for tool axis paralel to X axis, involves :
... g119
... if arches are needed : g132 133
... g40 41 42 obvious
... handling in-out compensation vectors, to avoid full C axis spin, as to avoid colisions on asimetrical shapes
... primitive diameter, in respect to section width
... tool offset shift, as the toolpath may not be designed on tool tip, but closer to the collet
... feed calculation, as CZ codes have different feed values, in respect to each axis; for example, feed for C only <> Z only <> CZ combos
... posibility to apply:
...... toolpath overall corections, especialy on non Y lathes, because toolholder may be offset in Y, not much, but > alowed tolerance
...... toolpath discrete corections, in geometry, depending on shape complexity
... HiCut for those small segments
a good postprocessor should handle all those
is not that okuma is complicated, but they allow adresing each atribute of milling with linear and rotary axis; as for next step, you can use inverse-time feed, as on 5 axis
please feel free to ask anything i can help you / kindly
