534,927 active members*
2,903 visitors online*
Results 1 to 8 of 8
    Okuma LT-15 alarm
    Hello everyone and Happy New Year. I am newbie working on a Okuma LT-15. It is throwing an alarm code 1784 1 A on the upper turret. If you hold the button down it spins but when you you release it, turret stops and faults out. I am trying to locate the limit switches on this. I have taken a couple of the covers off but not really seeing anything yet. I am not a machinist, I am just trying to help out a buddy. Any help is greatly appreciated!! Thanks
    Mar 2009
    1380
    Re: Okuma LT-15 alarm
    First of all: what happened? Was there a bang and turret is displaced a little?
    Looks like the turret is not clamping.
    Check if tool tip position is in the center of spindle rotation. Take the finish cutter and try to align the tip with the center of clamped workpiece. You will see the big mismatch without precise action. It means the turret is misaligned - displaced by bang.
    If not, there can be more reasons. Make sure the turret is aligned before you go to adjust the limit switches.
    It's easy to align the Okuma turret in case if it is installed correctly and tapered pins are taken away. Remove cover, loosen clamping bolts a bit and tap in the pins. This gives at least 50 µm accuracy.
    It was working fine before we shut down for christmas break. They shut the machine off and when we came back in Monday it immediately threw an alarm before even starting a first piece. I will look into aligning it next then. Thanks
    Where exactly are the proximity switches on this upper turret? I think one maybe loose or gummed up and would like to look at them before we call gossinger.
    Mar 2009
    1380
    take a picture of the turret, I will mark screws.
    easy visible on your picture at the start of this thread.
    I split the case yesterday. I left the back half on for now.
    Mar 2009
    1380
    have no idea why my pictures are not attached. I uploaded pictures to web hosting.
    "okuma _01.jpg" and "okuma _03.jpg" are mechanical switches. "okuma _02.jpg" follow the cable. The branch to left goes to pointed LS. A branch down goes to one more place.
    https://ibb.co/R4TmpYJ
    https://ibb.co/crXtM4t
    https://ibb.co/WxzwJbX
    I got them and greatly appreciate it. Will get to work tracking these down!!
  1. OKUMA MCS ALARM 817-4
    By luca27973 in forum Okuma
    Last Post: 07-11-2017, 11:36 AM
  2. okuma alarm 937
    By RINES in forum Okuma
    Last Post: 12-01-2016, 04:44 PM
  3. OKUMA VAC III ALARM 25 help
    By cnurcanli in forum Okuma
    Last Post: 01-12-2015, 10:13 PM
  4. OKUMA ALARM
    By okuma_sos in forum Okuma
    Last Post: 06-24-2011, 04:16 AM
