548,475 active members*
2,583 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > OKUMA MX-55 With U10M Control System
    Oct 2021
    Hii Everyone
    here i have okuma made VMC MX-55 with U!0M control system.
    i have a problem with Rotary table axis called A axis,when we run rotary axis in cycle mode, it rotate 360 degrees. But some times 1 or 2 times out of ten it rotates and return to 358 degrees and stop without any alarm and there is no stop in auto cycle, cycle run continously.
    so please help me to figure out problem i will be very thankfull to u all.
    Mar 2009
    1695
    Re: OKUMA MX-55 With U10M Control System
    Check with your specifications. Maybe there is a limit how many rounds the A axis can rotate before reset. That means the A axis cannot run the same direction continuously.
    There is a special chapter for Okuma in the forum. Name "Okuma".
  1. Okuma OSP-U10M DNC-B
    By MoldShopKY in forum Okuma
    Last Post: 08-31-2020, 03:21 PM
  2. Okuma OSP U10M Spindle control problem
    By ungie in forum Okuma
    Last Post: 04-21-2019, 08:51 AM
  3. Replies: 7
    Last Post: 01-11-2014, 11:09 AM
  4. Okuma OPS U10M control spare parts
    By brujo in forum Okuma
    Last Post: 05-17-2012, 01:48 AM
  5. Okuma osp-u10m
    By babanh in forum DNC Problems and Solutions
    Last Post: 01-18-2012, 02:29 PM
