585,760 active members*
3,898 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma MX Drill Cycle
Results 1 to 12 of 12
    Nov 2005
    196
    OSP 700m
    I need a can cycle that will rapid to Z.1 between holes to clear a hub, rapid to Z-.525 then drill to Z-1.2.
    Here's a program from GibbsCam. Not sure where Z.43 came from. Which line should have the Z-.525?
    O0001
    N1 G17 G40 G80 G94
    IF[VATOL EQ 1]NTC1
    T1 M6
    NTC1
    G15 H1
    S2000 M3
    G90 G0 X5.75 Y0.
    G56 Z.43 H1 M8
    G71 Z.1
    G81 X5.75 Y0. Z-1.2 R.1 P0 F4. M53
    X-1.7768 Y-5.4686
    Y5.4686
    G0 Z2.
    M9
    G30 P1
    X-18. Y12.
    M30
    Jun 2015
    4154
    Re: Okuma MX Drill Cycle
    hi i would code this long hand; is possible to use an R value and obtain what you wish for using a cycle, but i can deliver this code faster than looking for those cycle codes inside the manual; also there are things that a cycle can not deliver, so ...
    if you really wish for a can cycle, let me know, and i will be back with a code written how you wish / kindly
    Code:
        IF [ VATOL EQ 1 ] NJUMP
             T1 M6
        NJUMP ( NOEX )
        M08
        G15 H1
        G56 H1
        S2000 M3
        G00 Z0.43
        CALL OSUB LV01 = xa LV02 = ya
        CALL OSUB LV01 = xb LV02 = yb
        CALL OSUB LV01 = xc LV02 = yc
        M05
        G00 Z0.43
    M02
    OSUB
      ( G00 Z0.1 )
        G00 X+LV01 Y+LV02
        G00 Z-0.525
        G01 Z-1.2 F? G95
        G01 Z-1.2+0.3/25.4 i guess your coordinates are in inches
        G00 Z0.1
    RTS
    Nov 2005
    196
    I would prefer to use the can cycle. I'm surprised nobody knows how off the top of their head. Maybe it can't be done with a can cycle.
    Dec 2008
    3109
    Quote Originally Posted by Technical Ted View Post
    I would go
    G56 Z.5 H1 M8
    G71 Z.5
    G81 X5.75 Y0. Z-1.2 R-.5 F4. M54
    M54 forces return to G71 position
    M53 forces return to R position
    Jun 2015
    4154
    hello super carefull sunshine, maybe M53 is for G71
    hello technical teddy i have attached some infos from the manuals, related to your drilling stuff
    code shared in this post uses G81 / kindly
    Code:
             T1 M6
        NJUMP ( NOEX ) (*4)
        M08
        G15 H1
        G56 H1
        S2000 M03
        G00 Z0.43
        G71 Z0.43
        G81 X10 Y10 Z-1.2 R-0.525 ( P+60/2000*0.6 ) F0.15 G95 M53 (*1)
            X20 Y20
            X30 Y30
      ( G00 )
        G80
      ( M05       ) (*3)
      ( G00 Z0.43 ) (*2)
    M02
    (*1) ( P : dwell time for 0.6 rotations, thus for 0.6*360=216 degrees )
         ( formula should contain actual rpm )
         ( formula may fail in case of override potentiometer <> 100% )
         ( in your code, from post 1, is no delay : P0 )
         ( you may avoid the delay for through holes, cut within 1 shot; if you peck, or if there is a blind hole, than delay a bit )
         ( also there are alternatives to delay, like the retreat movement among 0.3mm, in feed, shared in the code from post 2 )
    (*2) ( no need to rapid up, because Z is allready @ safe Z, before executing G80 )
    (*3) ( spindle was stopped when G80 was executed )
         ( if you wish to avoid spindle stopping, then remove the brakets from G00 that is before G80 )
    (*4) ( check if it works to remove the brakets from NOEX )
    Dec 2008
    3109
    Quote Originally Posted by Superman View Post
    I would go
    G56 Z.5 H1 M8
    G71 Z.5 (this sets the clearance plane )
    G81 X5.75 Y0. Z-1.2 R-.5 F4. M53
    M53 forces return to G71 position before next hole
    M54 forces return to R position before next hole
    for each option
    each I or Q peck retracts to R plane. so care is needed if swarf needs to be removed
    oops
    Nov 2005
    196
    I gave up & went with a long hand program instead of can cycle. Using either M53 or M54 I could get it to retract far enough but it always feed from that point instead of rapiding back to Z-.5 & feeding from there.
    Jun 2015
    4154
    hi technical teddy
    is good to code longhand, or at least to know the codes ...
    i shared 2 codes in this thread : both rapid up + reposition + rapid in; one is long hand, the other has cycles
    if you wish, use them as a reference / do you have questions about them ? i tried to write them as simple as possible
    they are both tested on the machine, and they work / kindly
    Nov 2005
    196
    I didn't realize you had tested the program on your machine & it worked. We loaded your can cycle program into our machine & it also worked for us. We then tried my program again & it also worked. Not sure why it didn't work the 1st time, maybe the other operator had the rapid override too low & thought it wasn't rapiding. Thanks for the help & sticking with me to get this resolved.
    Jun 2015
    4154
    hy teddy
    come on man, only looking at those codes : layout, indenting, paragraphs, comments, vertical alignments : doesn't it seem tested ? or you thought that i like caligraphy ?
    caligraphy comes 2nd ... content is 1st do you wish for a messed up code ? just say it
    improvements can be done:
    ... faster editing times
    ... shorter cycle without messing with the cutting specs
    ... random sh**t that delivers
    * would work on osp300, maybe 200 ?
    maybe is a good idea to test codes yourself, and when you are sure, pass it to the operator ... just saying
    i am not telling you what you should do, but you seem more prepared with this stuff than your operator ...
    is ok ... if somehow you get rich ( and famous ), and maybe you will have a spare lamborghini ...
    kindly
    Nov 2005
    196
    A Lambo doesn't seem like it would be practical in Antarctica.
    Jun 2015
    4154
  1. G82/83 drill cycle
    By Nazu1984 in forum Haas Lathes
    Last Post: 12-10-2012, 09:57 AM
  2. Help with Drill Cycle
    By Bradan Eudy in forum Cincinnati CNC
    Last Post: 03-27-2012, 08:33 PM
  3. Drill Cycle
    By metlshpr in forum Haas Mills
    Last Post: 06-28-2011, 11:05 AM
  4. DRILL CYCLE
    By metlshpr in forum Mastercam
    Last Post: 06-27-2011, 03:18 PM
  5. trying to ues a G83 drill cycle
    By firekoe in forum Fanuc
    Last Post: 04-27-2010, 04:45 PM
