585,977 active members*
3,968 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma open door message at startup
Results 1 to 6 of 6
    Apr 2008
    49
    On start up, the screen displays (please open door). It does not unlock the door. This is a newly acquired 2007 L370 with P200L control. It was setup with auto door and a robot. Robot is now out of the picture.
    Apr 2009
    1262
    Re: Okuma open door message at startup
    Press the door open button upon startup. It needs to verify that the door lock is “still there” after boot up. Once verification takes place the alarm will go away. You will need to be in manual mode for it to work.
    Best regards,
    Apr 2008
    49
    I needed to be in manual mode. Thanks OkumaWiz.
    Apr 2009
    1262
    :wave:
    Experience is what you get just after you needed it.
    May 2022
    3
    I was wondering if there is a way a west ham locksmith could fix that. Maybe there is a mechanical issue that needs to be fixed by somebody who knows the mechanics of a lock
    May 2022
    Quote Originally Posted by JaymeL View Post
    I think its much more about robotics, and if a locksmith is not an Engineer,he does nothing to do about it
  1. Replies: 1
    Last Post: 01-07-2021, 09:05 AM
  2. Haas OM2A Door Open Door Hold
    By kaymteo in forum Haas Mills
    Last Post: 07-29-2020, 03:28 PM
  3. Replies: 16
    Last Post: 06-12-2020, 03:18 AM
  4. Error Message on startup
    By gunmaker in forum Milltronics
    Last Post: 01-03-2019, 05:48 PM
  5. Replies: 8
    Last Post: 04-04-2015, 02:59 AM
