589,272 active members*
5,069 visitors online*
Results 1 to 11 of 11
    Jul 2005
    7
    Question Okuma OSP-U10
    What is the PUNCH and READ keyboard commands on the Okuma OSP-U10L control?
    It was all set up but then the operatoro left the company and I don't know what to type in at the machine control to get it to SEND and RECEIVE files out the RS-232 serial port.
    Thanks.
    Feb 2010
    Smile
    you can also add programs thru floppy disk to the machine.
    Jan 2010
    Talking PUNCH & READ COMMANDS
    It can make a difference on how your machine is wired to your DNC but usually it is Punch TT: write, to save files & Read TT: write, to load files into the control. To load a file into the control you would get your DNC file set and tell it to Download the file, you would then go to the machine control in Edit and tell it to Read TT: and push write
    To upload a tape file you would get your DNC file ready and tell it to Upload the file, you would then go to the control and pusg Edit, Punch TT:O19688 ( File Name)
    We have some older controls that have two channels of communication setup.
    CN1: is for tool offsets & CN0: is for part programs. This allows the baud rates to be set differenty so the info does not get jumbled up on the tool offset files we save.
    Jul 2005
    7
    Doesn't "PIP" come into play somewhere?
    I also remember "CNC0:" in there also?
    Thanks.
    Jan 2010
    Talking PIP READ-------PIP PUNCH
    Yes you are correct.
    Edit, PIP, PUNCH, (file Name), WRITE or enter, same difference.
    Edit, PIP, READ, TT: WRITE
    CNC0 I have not heard of or used. We use CN1: & CN0: on our older OKUMA MC60H 5-Axis Horizontal Mills with the OSP500M-G control and we have an older MC5VA that we only use TT:
    As I mentioned before we use TT: on our newer Machines that are MC60HB Horizontal Mills that have the OSPU100M-H controls.
    If you do not not what works, keep trying until you find the one that works for how you are wired up.
    Good Luck (nuts)
    Jan 2010
    Talking
    OOPS!
    That should have read OSP5000M-G, not 500.
    Dec 2008
    3147
    For the older machines
    many were set to a default TT: if you did not specify the port that the data was intended to go to
    TT, is a paper tape reader
    CN0: is the primary RS232 port
    The default can be set to CN0: by using the installation setup disks
    so if you say <PIP> <READ> <WRITE> you are asking the machine to accept data thru the default port
    but
    if you say <PIP> <READ> CN0: <WRITE> you are asking the machine to accept data thru the RS232 port, no matter what is set as the default
    The manual should show that commas can be used, but is not explained properly
    <PIP> <READ> CN0:,[filename.MIN] <WRITE> ( note the comma before the filename after CN0: )
    this tells the control to accept the data and rename it to that filename
    the 1st line in the program is used to define the programs name---it is optional , it must begin with a $ and must end with a %
    If reading into the control using <PIP> <READ> <WRITE> , the 1st line name is given to the file, if omitted then A.MIN is the name given to it.
    .MIN is the default extension and it can also be omitted
    Mar 2009
    1982
    generally saying, Mr.Superman is right. There are more important details, however. Serial communication is simple, when You understand it.
    Had never tried to set that way. It's in the parameters. Pay attention: there are different settings for reception and transmission ... ehm ... I mean different port settings for file send and for receive.
    Jan 2010
    96
    Hello. I have the manuals you need for the U control that will help you with all the things you need in this area. Let me know an e-mail and i will get them to you. They are in Adobe pdf format.
    Aug 2011
    430
    Quote Originally Posted by CNCZILLA View Post
    Hi CNCZILLA
    I need manuals of Okuma U control and OGL. Please send me PDF. Thanks. [email protected]
    Re: Okuma OSP-U10
    Hi.
    We are installing the DNC solution from Predator (shopfloor Automations) on our machines and we are facing the following problem:
    On all our Okuma Lathes, OSP100L and OSP7000L we can punch out without any problems but when we read the file name allways turns to A.MIN, we tried to change Parameter #12 bit 7 for file name allowance but still we get A.MIN
    Any idea what could be the cause?
    Gert
  1. Replies: 4
    Last Post: 10-02-2014, 04:58 AM
  2. Replies: 2
    Last Post: 11-11-2010, 09:37 AM
  3. Okuma Howa Vs Okuma
    By gcrudgington in forum Okuma
    Last Post: 07-01-2010, 03:11 PM
  4. Replies: 1
    Last Post: 08-28-2008, 02:09 PM
  5. Difference between a Okuma & Okuma Howa
    By 69owb in forum Okuma
    Last Post: 06-04-2008, 05:51 PM
