589,420 active members*
5,782 visitors online*
Results 1 to 5 of 5
    May 2022
    5
    Post OKUMA OSP7000L
    hello we have problem with cnc lathe OKUMA 2 axis cnc lathe control OSP7000L
    we have all floppy disks for machine
    3 batteries were discharged, we replaced them with new ones, but I don't know what to do now
    we have a CPU error 1-1 BUS error
    Attached Thumbnails Attached Thumbnails IMG_9635 (1).jpg   IMG_9634 (1).jpg   IMG_9637 (1).jpg   IMG_9636 (1).jpg
    Aug 2006
    148
    Re: OKUMA OSP7000L
    We were in the same spot. We had all the disks that came with the machine but that's not enough. Sadly in our case we had to have Okuma come out with their special disk to get the machine running after the battery change. If anyone knows of another way please chime in.
    "Teach the ignorant, care for the dumb, punish the stupid."
    Re: OKUMA OSP7000L
    Hlo
    I am a cnc machine retrofitter, doing retrofitting with Syntec controller.Please dont take it personally, If your cnc controller is too old & you facing issues, you can contact me at [email protected] & +918168294379 (whatsapp). I am already working with many clients from USA,Canada,vietnam etc.I can arrange New or Old Syntec controller as per your application and requirement.
    Thanks & Regards
    Pankaj (+918168294379)
    May 2022
    5
    Re: OKUMA OSP7000L
    so It is necessary for the service to arrive with an appropriate diskette to replace the battery? and the machine will be works?
    Aug 2006
    148
    Re: OKUMA OSP7000L
    We have an OSP700L and U10L and yes we had to get Okuma to come for the battery change. I thought it was weird but have not found another answer. I'm hoping someone turns up here with an alternative.
    Aug 2011
    430
    Re: OKUMA OSP7000L
    You must initialize memory disk before installing software
    "Imagination is more important than knowledge."
