Dear All,
we have okuma ops 200l lathe and all program and function are working but operator panel display was flashing and gone dark. can anybody advice me that if i could use any other display and connect to the machine.
thanks..
Dear All,
thanks..
use bright flashlight and check if you can see some signs of display life. Maybe backlight is faulty only - easy to fix
balavishe,
I was monitoring this site and saw your post.
Since you are located in India, have you tried to contact your local Okuma distributor? This link is for a page that lists all of their locations. They should also be able to assist you with acquiring the parts you need.
http://www.okumaindia.com/contactus.html
Best of luck.
Mindy Mikami
Okuma America Corporation
Hello Algirdas,
I'm encountering an issue with our Okuma OSP200. The display is only visible when I use a bright flashlight; without it, the screen is just black. What do I need to do to fix this?
Thanks!
