585,591 active members*
2,553 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma Pallet Changer Crash
    Aug 2021
    16
    I recently got a Okuma MX-45VAE with a OSP700M control from an auction. I got one of the board fixed, added new oil, then moved the axes. Then I tried the pallet changer out in manual mode. I got the machine to move over in X, the door to open, and the pallet to unclamp. Then it wouldn't do anything else. I found the page that says the sequence number and the parameter page that has the APC sequence number. The sequence was step 6. I didn't realize this later but pallet "B" was loaded on the machine and pallet "A".
    I have tried many thing to get it to move so I am a little fuzzy on what I did. But here we go I changed the sequence number to 7 and pallet A moved to the load position even though pallet B was already in the machine.
    Then I changed sequence number to 6 (if I remember right) and it started to pull pallet B out of the machine even though pallet A was in the way.
    How do put pallet A ( the one on the pallet changer ) in the storage position ( front of the machine)?
    How do I put pallet B back in the fully loaded position in the machine?
    Oct 2009
    114
    Re: Okuma Pallet Changer Crash
    Hellog
    I think there is a missing diagnostic message. The missing diagnostic message is splash guard open signal that is not in screen.. You have to be careful when doing with parameter. You have to know the sequences.
    Aug 2021
    16
    Thanks for replying. I put in the sequence number in and pushed APC reverses and it sent it to the right place.
    Also it turns out the riggers attached some of the wires in the control box backwards.
    Now it works correctly.
  1. Pallet changer
    By JackDeRam1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-26-2012, 08:13 PM
  2. Pallet Changer
    By MIDDEN300 in forum CNC Machining Centers
    Last Post: 09-20-2008, 02:32 PM
  3. Tool changer crash
    By Vern Smith in forum Haas Mills
    Last Post: 05-05-2008, 11:36 PM
  4. Pallet changer stuck
    By Jedi in forum Uncategorised MetalWorking Machines
    Last Post: 07-13-2006, 09:43 AM
