585,926 active members*
3,580 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > OKUMA RENINSHAW programming help
    Sep 2011
    3
    Hi all I come with a desperate need of help. I have a part that is cast. and I need to position the part on an okuma MU-400 5axis. I need to position the part, so I need to level the part on A axis and put it strait on C axis. and also to find the middle of the part. the part is a segment from a big die, and is radial it dose not have straight faces. only radial. I only need to machine some portion only.
    Can someone can help me?
    Also if you have an idea to take origin when the table is not on C0 A0.
    Feb 2009
    13
    Which control does your MU400 have? Do you even have the Renishaw macros? Or are you probing with the Okuma macros?
  1. okuma lathe programing software help
    By ironmike2682 in forum Uncategorised MetalWorking Machines
    Last Post: 02-14-2013, 02:58 AM
  2. Online cnc programing/ offline cnc programing
    By grimantas in forum Polls
    Last Post: 11-28-2012, 02:03 PM
  3. Okuma OSP 3000l Programing
    By adohrman in forum Okuma
    Last Post: 03-12-2012, 05:05 PM
  4. Okuma OSP-P200L Programing
    By trampus in forum Okuma
    Last Post: 11-19-2010, 04:35 PM
  5. Okuma IGF Programing
    By Maggy in forum Community Club House
    Last Post: 09-23-2010, 05:53 AM
