589,388 active members*
6,918 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OKUMA SPACE TURN LB 3000 EX OSP-200L
Results 1 to 9 of 9
    Jun 2024
    5
    Ok so been in manufacturing for about 6 years and I'm still pretty green. I mostly ran Fanuc and haas controls at my previous job. I moved on from my previous job and started a new one about a year ago. When I started the one lonely Okuma lathe just sat off I would ask questions but the guys in the shop would say that thing is "impossible" to run without mastercam and that machine has a "different language" I get it the guys here only know manual guide i they don't know g code and they refuse to use mastercam even tho its available to anyone here. So my curiosity got the best of me and I have been trying to teach myself to run it. I can get most things done on it with mastercam which I taught myself to use as well so im not very good at it. I have hit a hiccup and im trying to figure out how to use an endmill to mill a groove around the OD of a cylindrical part. The program mastercam spit out doesnt work I have attached a screenshot of verify. I also have to mill that slot on the front of the part o and the part is hardened to 56 RC . I have found a programming manual I am going through but I will take any information and I mean any information on running this thing. Dont be too harsh on me tho.
    Jun 2024
    5
    Re: OKUMA SPACE TURN LB 3000 EX OSP-200L
    here is the code mastercam gives me.
    Jun 2015
    4172
    hello, i can help you to code it
    it involves custom feed math, because of the rotary axis / kindly
    Jun 2024
    5
    ill take any help i can get and it will be greatly appreciated
    Jun 2015
    4172
    please check your private message on industry arena, like attached
    Dec 2008
    3148
    Points to you for giving it a go...
    Your mastercam code ... line 24 ... is that an F0. for any feed moves (G1,G2,G3), won't go anywhere if it is.
    Mastercam planes are a b$tch to get right, if you look from RIGHT view, the 3 o'clock position is 0° for milling.
    ... similar goes for turning ...
    TOP view.. above centreline for upper turret toolpathing contours.. which is the 0° line
    TOP view.. below centre for lower turret paths.
    Jun 2024
    5
    yea its a F.0 but I have tried every number and it still just alarms out. I agree the planes are tough but im trying to work through it. the coding on the okuma is jus so different.
    Aug 2011
    430
    Quote Originally Posted by hurf130 View Post
    Hi
    Check line 17
    I think there is a mistake on tool&offset number
    "Imagination is more important than knowledge."
    Jun 2024
    5
    Ya I ended up getting it to work using a different toolpath in mastercam. The tool number and feedrate were wrong in the program above but those werent causing the issue.
  1. Okuma Turn Space LB300
    By ultimatron in forum Okuma
    Last Post: 05-16-2015, 08:31 AM
  2. osp 3000 for an lc20 okuma
    By gmsmachinists in forum Okuma
    Last Post: 11-25-2014, 02:20 PM
  3. Okuma MAC TURN 250 OSP 200L
    By ste836 in forum Okuma
    Last Post: 06-16-2011, 11:51 PM
  4. OSP 3000 TURN DEMICAL ON
    By sway825 in forum Okuma
    Last Post: 06-25-2009, 02:06 PM
  5. OSP 3000 okuma code.
    By Tonenc in forum G-Code Programing
    Last Post: 04-24-2006, 08:28 AM
